How hard is it to installmotor mounts?
Old May 25, 2006 | 05:39 PM
wiretap's Avatar
yea.. I was going to attempt to install my RRM solid motor mounts, but laying under there with the car 4 inches off my chest and all the extra turbo piping and wastegate in the way of the front one.. I decided just to get them professionally installed instead of going thru the hastle. They are going in next week.
Old May 25, 2006 | 06:57 PM
comatose721's Avatar
i wish i had that problem hahaha
Old Aug 17, 2006 | 05:18 PM
Kurt's Avatar
Can someone point me in the right direction in how to get that rear motor mount out. I am replacing my mounts with the one from Deyeme and I got the front one done without a problem but the rear one is fighting me.
Thanks in advance.
Old Aug 17, 2006 | 06:59 PM
revolt4revolver's Avatar
tap did you buy motormounts before you bought an intercooled turbo setup?
Old Aug 17, 2006 | 07:27 PM
Handmemyarms's Avatar
uhmm, im gonna go ahead and guess no he didnt considering that the piping was in the way when he tried to install the mounts hahahaha.... wow
Old Aug 17, 2006 | 07:59 PM
http://en.wikipedia.org/wiki/Rhetorical_question
Old Aug 17, 2006 | 10:30 PM
Edited: sometimes is just easier to call someone a moron then explaining the technical aspects
Old Aug 18, 2006 | 07:08 AM
Blacksheepdj's Avatar
Thanks in advance.
No good tips. That ****er will fight you. Just gotta wiggle and pray and stuff.
I'll go light a candle for you.
Old Aug 18, 2006 | 07:18 AM
Kurt's Avatar
Thanks. The fight will continue tomorrow morning.
Old Aug 18, 2006 | 05:15 PM
03RallyLancer's Avatar
to get it out i suggest removing the intake and you are going to have to remove the bracket it mounts to the engine on. Also LOTS of penetrating oil.
Old Aug 19, 2006 | 09:03 AM
Kurt's Avatar
Well the fight has ended. After crushing two fingers, it is off to the mechanics to have this last mount done.
Old Aug 19, 2006 | 10:59 PM
phil_'s Avatar
I did my mounts recently, they went in with a little elbow grease, not to bad IMO. JUst had to figure out how to get the bolts at the proper angles to install. A racheting closed end wrench was my saviour for that install!
