Water Puddle, No start
Old Jun 26, 2006 | 08:29 PM
  #31
Smoku's Avatar
so how much is the damage.. what should i do..
Old Jun 26, 2006 | 08:33 PM
  #32
Walkingchaos's Avatar
replace the engine, youve blow all the internals and wasted your oil pan. Probably fried some stuff in the electraical system too.
Old Jun 26, 2006 | 08:35 PM
  #33
Smoku's Avatar
that is f'ed up if its true. ill like kill myself.. costs?
Old Jun 26, 2006 | 08:51 PM
  #34
well there are lancer motors around for less then a grand, but install is gonna be pricey. Im sorry bro but ya more or less just totaled your lancer
Old Jun 26, 2006 | 09:57 PM
  #35
Z_Lancer_Man's Avatar
There are many Lancer engines on ebay for about $650 shipped. So the swap yourself and save a ton of money - there are enough people on here who've rebuilt/reinstalled engines that you can get help.
http://search.stores.ebay.com/lancer...QsifZ1QQsofpZ4
Just a side note for those of you who are reading. This problem (destroying your engine) could have been avoided if the $40 bypass valve was used. I personally have been running a cold air intake for 2.5 years without the valve cuz I never wanted to cut my pipe in half to fit it. Now when i see this..... $40 and cutting pipe >>> $650 and installing a new engine.
Sorry this had to happen to you Smoku......
Old Jun 26, 2006 | 11:09 PM
  #36
Moral of the story, Lancers were not made to offroad ! Goodluck Smoku
Old Jun 27, 2006 | 12:04 AM
  #37
Myszkewicz's Avatar
Bionic Auto Parts - IL(Chicago) 1-800-626-9618
They show about a dozen engines for your car, mileage ranges from 31k to 71k. Take your pick for $605. Rent an engine hoist, and invite a couple mechanically-inclined friends over. You should be able to get your car back on the road for less than $800.
Old Jun 27, 2006 | 11:50 AM
  #38
Smoku's Avatar
i was hoping to hear better news..
Old Jun 27, 2006 | 10:07 PM
  #39
Myszkewicz's Avatar
Sorry, but there's holes in your block. Those don't happen from water splashing on it. Whoever said you have at least one broken connecting rod is right, I'm afraid.
Good new is that you'll have a spare of everything but the block, oilpan, and a connecting rod or two. Part out your old engine, sell off the stuff you don't need, and make back some of the money you'll have to spend on a junkyard engine.
Old Jun 28, 2006 | 12:02 PM
  #40
Smoku's Avatar
would i be able to find out if the engine is broken from manually cranking it? im about to go and take out the spark plugs.. and see. also i could take the valve cover off and maybe see something from there?
Old Jun 28, 2006 | 12:54 PM
  #41
Smoku -
We're all very sorry, but I think you're in denial. There are HOLES - HOLES, HOLES in your engine block. That is caused by serious internal failure. Unless you smashed into some rocks while driving that could break a hole in your aluminum oil pan, the holes are caused by catastrophic engine failure. Taking out the spark plugs won't reveal anything. You need, must remove the upper oil pan. There are a ton of bolts that hold it to the block. Where the pan, block and tranny meet is a little space where you can slide a flat head screwdriver in and pop off the pan. Once the pan is off, you can them see the rods and crank and find out what is broken. Here is what your crank/rods should look like (my engine when I did the turbo install)
Old Jun 28, 2006 | 04:25 PM
  #42
Smoku's Avatar
actually i dont need to do any more checks to see if my engine is ok or not. i have a huge hole next to my dip stick where u check oil.
im calling my insurance tomorrow.
my car year is 2003 and it has 57000 miles. do you guys think they will total it? i think it has engine to change and some electrical parts as it wont crank.
if insurance will total my car..
im selling my front lights with hids..and back altezzas.. along with strut bar. broken cold air intake. its broken at the part where u screw it at the bottom. u wont be able to screw it in unless u create some hook up. also you will need to get new filter.
and if they do total my car.. i think im getting an used mazda 6.. 12000$ .. 22000 miles.. all leather.. good deal yea?? ;P
Old Jun 28, 2006 | 04:29 PM
  #43
Smoku's Avatar
here is the hole by the dip stick.. hard to see. phone camera
Old Jun 28, 2006 | 07:33 PM
  #44
So the Lancer days will be over. Sorry to hear about this. Good luck in whatever else you get. That Mazda should be a good start
Old Jun 28, 2006 | 07:38 PM
  #45
Smoku's Avatar
well i dont know what the insurance will say.. if not mazda then scion.. or gti.
