Rrm Crank Pulley
Old Nov 16, 2006 | 02:09 PM
  #31
ROCK's Avatar
Originally Posted by BEANIE
i just installed my new RRM crank pulley and i got to say what a difference, not like a crazy difference but a noticable one all i have to say about it is thank you RRM you did a good job...
That is a sexy pulley. You car looks cool too. Thanks
ROAD/RACE
Old Nov 16, 2006 | 03:10 PM
  #32
atilla's Avatar
Originally Posted by sandman43103
sadude- What can be done to prevent the timing from getting messed with the timing belt off? I want to do the replacement myself, but the timing is my biggest concern since I'm not solid on how to set it back should something move.
the timing belt was kind of a PITA--and i don't mean flat bread.
you have to jack up the motor after removing the side motor mount and the timing belt cover. after all is said and done it's not too bad once you get down to the nitty gritty. there are marks for where your top dead zero is, you just have to look close. it helps to have a second person standing over you watching the cam gear so they can tell you when they are aligned. you may have to crank for a little bit before you get it aligned right.
as long as you get the motor set to top dead zero before putting the new belt on you should be okay. here's a little more info:
http://www.asashop.org/autoinc/jan98/timing.htm
Old Nov 30, 2006 | 09:29 AM
  #33
ROCK's Avatar
IT is still not too hard and again, you get good instructions. Figure you need 3 or 4 tools to install it.
ROAD/RACE
mcdeanjr
Lancer Engine Tech
Jan 20, 2009 05:51 PM
the_cosworth
Lancer Engine Tech
56
Aug 9, 2007 09:16 PM
iufan4lifeul
Nov 9, 2006 05:42 AM
Racer24x
Lancer Engine Tech
Jun 26, 2006 10:13 AM
Red Ralliart
27
Dec 5, 2005 06:43 PM
