Low Idle??..
Low Idle??..
wussup guys.. after i installed my SRI i noticed my car idles lower than before.. its idling under 1,000 RPMs.. is this normal??.. after i install my UDP will my car idles near stalling??.. thanks..
Idle speed should be 750 + / - 100 RPMs .... so unless you are extremely low to the point of stalling or extremely high (which is pointlessly wasting gas), you will be fine.
If you really need to, you can adjust your BISS screw to get a better idle.
What about the screw under the rubber plug on the top of the TB? What does that do to your idle. I've read what others say but any other opinions on that would increase the total number of people polled, if you know what I mean.
Originally Posted by sdhes
Is this idle while in Park or when in Drive, like at a stop light?
I see you are in Orlando, I will have to look for you when I get the Mirage done.
darwin_evo
36
Jul 11, 2013 07:10 AM
Smurf Rocket
24
Oct 22, 2010 06:00 AM
diiirk@AwdMotorsports
Apr 24, 2008 11:31 AM
