Finally got my Pistons!!!
Old Jan 16, 2007 | 02:20 PM
Mirage2.0's Avatar
Ok. I got than and I need a lavor from anybody that bought pistons before. Could you look at the specs and see if everything looks fine. I hope that the clearence which is .003 should be fine. From all the papers that I got, they don't mention the compression. I asked the guy and he said it should be 11.0:1. I'm clueless. Cheack it out:
P.S. I got the rings, just didn't take the picture of it.
Old Jan 16, 2007 | 03:54 PM
DemisedGabe's Avatar
nice..
Old Jan 16, 2007 | 06:07 PM
lancerman360's Avatar
yummy
Old Jan 16, 2007 | 06:50 PM
Geo_lancer's Avatar
hurry and put em on dude!!
Old Jan 16, 2007 | 06:54 PM
ambystom01's Avatar
I'd recommend getting a new head gasket and new head studs while you have the engine apart. Be sure to get the thing tuned at the same time, I doubt you can simply run 11:0 compression without some tuning.
bluebyu36's Avatar
should af went high compression.
Old Jan 16, 2007 | 08:10 PM
Mirage2.0's Avatar
ambystom01: I have it covered and the car is going on the dyno.
bluebyu36: Why are you saying that? What did you do?
Old Jan 17, 2007 | 08:45 AM
senate6268's Avatar
Originally Posted by Mirage2.0
The specs look good. They match the numbers on the spec sheet for the 10.5:1 pistons I used to have from Ross.
Old Jan 17, 2007 | 10:06 AM
SLVROZ_03's Avatar
I see dome-age, so I can only assume higher compression pistons there...
Old Jan 17, 2007 | 03:47 PM
Mirage2.0's Avatar
Yep. 11.0:1. Thanks guys. I'll keep you posted.
Old Jan 19, 2007 | 06:23 AM
Blacksheepdj's Avatar
Um, what do you expect? What are you calling high?
Stock compression ratio is 9.5 - how high are you expecting him to bump it?
Old Jan 20, 2007 | 08:24 PM
Elvis's Avatar
hey you gonna get the conrods to.
Old Jan 21, 2007 | 06:20 PM
Mirage2.0's Avatar
Nope.
Old Jan 21, 2007 | 06:23 PM
twostep's Avatar
Who makes those pistons?
Didn't they come with some type of a data sheet?
Old Jan 21, 2007 | 06:29 PM
Mirage2.0's Avatar
Ross pistons. There is data sheet but they don't mention the compression.
