Help 02 Lancer Wont Start
Old Jan 26, 2007 | 11:24 AM
CHOZEN_Lancer's Avatar
Originally Posted by mvarcola
Well hate to open ths can of worms, but I am having the same problem. I am getting spark from one of the coils packs and not the other one. Are you getting spark at all to either? My car has been sitting in the garage for almost two weeks awaiting parts.
no both of my coils arent firing. theres nothing getting to the coils.
thanks for all the info guys! ima replace that crankshaft position sensor asap and see what happens.
Old Jan 26, 2007 | 01:19 PM
rhyzin's Avatar
good luck and have fun getting to it.
Old Jan 26, 2007 | 04:05 PM
lol i know what you mean rhyzin. anyone have a diagram or picture of what it looks like?
Old Jan 26, 2007 | 05:14 PM
atilla's Avatar
if anyone knows the part number i am sure i can find a diagram of it in CAPS... i don't know where to go inside of CAPS to go to find it myself though. i looked, but i didn't find anything.
Old Jan 26, 2007 | 06:10 PM
Myszkewicz's Avatar
Gotta take off the lower timing belt cover, and everything in the way of doing so. Part #6 in the first linked pic. Unplug #1, remove whatever you need to to remove #6. The sensor is behind it.
Here:
and
HUGE exploded view pic
HUGE pic of sensor.
Old Jan 26, 2007 | 06:13 PM
mvarcola's Avatar
Thank you, I could not get the picture to post up here. Operator error!
Old Jan 26, 2007 | 06:59 PM
##TEARdrop##
i love you guys**sniff**
naw but seriously thanks alot for the diagrams. Those reallly clear things up. anyways check this out. i brought a part from my lancer into autozone to get it cross referenced since i couldnt find it anywhere and the "intelligent" dude at the desk typed away in to their database and then told me that the part i was holdin IN MY HAND didnt exist. lol i really laughed
Old Jan 26, 2007 | 07:01 PM
ordered the part online
$65 and sum change shipped in 2 days.
Old Feb 12, 2008 | 10:09 PM
lancerrally45's Avatar
well it has also happened to me just the other day. no spark, fuse good, coils good. i need to get back on the road, its my dd. everyone end up saying it was the crank position sensor?
Old Feb 13, 2008 | 12:26 PM
SLVROZ_03's Avatar
Yep, sounds like a CPS for sure. It's not that it necessary "went out"...but that the contact points of the sensor and the plate that spins with the crankshaft are dirty. A tad bit of parts/brake clean cleaned it right up for me! Did it while I changed the T-belt actually.
Good luck guys!
Old Oct 16, 2012 | 09:08 PM
lt88's Avatar
Please help my 2003 lancer is having similar issue, a few weeks ago when my car was still working it drives fine but it would randomly shut itself down and now wont start, the most frustrating part is tat i didnt get any check engine light so in this case i started to randomly check all my parts, so far i've change the crank position sensor since this is what most people recommend but no luck, check all basic but everyting seemed fine.....n what **** me off is that this car only has 90xxx n already ***k up on me , i baby this car n maintenance it regularly...oh yeah not to mention i already have the dealer do the reflash on it n didnt fix the issue...if there's anyone that found a solution please do share it because im pretty sure theres alot of us right that are going through the same issue with our cars.
Old Oct 16, 2012 | 09:30 PM
03lances's Avatar
It sounds to me like you have a short somewhere either a ground or something with an intermitent connection. I would start by checking all the relays. Could very possible just shut down the car out of no where and eventually (as you have now found out) stop working all together. Check everything that pertains to the ignition system. If it was the fuel pump/ injectors then the car should have spit and sputtered before dying everytime so if it just shuts off then this strongly supports the spark is getting cut for some reason. Since you already changed the CPS I would check out the cam sensor and relays pertaining to the ignition system as well as all the connectors to the coils, sensors, etc. even check the ecu connectors to be sure those are not loose somehow.
Old Oct 17, 2012 | 10:59 AM
lt88's Avatar
thanks for ur response, i will look more into the things u pointed out, will reply with result this weekend thats if i get any lol, times like this i just wana cry and laugh
Old Oct 21, 2012 | 11:17 AM
lt88's Avatar
aite i figure out what the problem was, one of the 12v relay in front was bad so i switch it with another one n my car started up( this was random didnt kno it was bad), didnt die on me no more, so guys that have similar issue check all ur fuse n main relay switch them out if u have some spare ones, before start buying expensive parts, n dont change any sensor unless u get a code, my didnt throw any code n i change my crank sensor fo no reason, thanks to those that respond
lancer586
Lancer Troubleshooting
42
Apr 10, 2021 02:16 PM
benny23
Jul 31, 2015 10:57 PM
regan6678
Mar 30, 2014 11:09 AM
Viet-Speed
Apr 23, 2013 03:57 AM
RalliMark
Nov 23, 2011 06:51 PM
