idling jumping while car is at stop
Old Jan 28, 2007 | 02:42 PM
Tha one's Avatar
when im at a stop light my idling starts to jump frm 1100 rpm than dwn to about 800 900 rpm than jus keeps jumping between those rpm. idling at stop is roug. dny knw wut it is.
Old Jan 28, 2007 | 02:43 PM
ambystom01's Avatar
Any mods? Auto or manual?
Old Jan 30, 2007 | 04:20 AM
Tha one's Avatar
exhaust, intake, manual, and jus put on a test pipe frm rrm, but it was happening before i installed my test pipe
Old Jan 30, 2007 | 04:38 AM
Newfoundlancer's Avatar
I have the same thing happen at times... for me it's the Air Conditioning compressor kicking in and out... even when I have A/C turned off!
Old Jan 30, 2007 | 07:40 AM
Go2fast's Avatar
Sounds to me like a vaccum line is off maybe......? Maybe you took one off when you put the intake on? Hummm.... Any check engine lights? Reset the computer by disconnecting battery for a few mins!! And last of all go get some injector cleaner (recommend the brand GUMOUT) and put it in your gas. maybe you have dirty injectors. I run it threw every month or so. The idle gets better. Try all that and let me know.
Old Jan 30, 2007 | 09:14 AM
Tha one's Avatar
yea the engine light is on but i had took it to the dealer and said it was my catalytic converter the first one, so im thinkin of buyin tha rrm headers and hopefully the engine light will turn off and i get normal idling. and i will check my vacum hose and run sum injector cleaner and hopefully that will help a lil bit. thanks
Old Jan 30, 2007 | 09:31 AM
Go2fast's Avatar
Was the light on before you did the testpipe?? If so, if they said it was your first cat then your O2 sensor that reads air/fuel mixture is that cat and may have gone bad. How many miles are on your car?? My advice is to go to Discount Auto Parts or Autozone and have them read your codes. There machine will tell you if its the O2. Also, has your gas mileage gone down???
Old Jan 30, 2007 | 09:54 AM
ambystom01's Avatar
Might be because of the CEL.
Old Jan 30, 2007 | 09:57 AM
Tha one's Avatar
yea it was on before tha test pipe was installed. it may be the o2 sensor but tha dealer said my sensors was fine and that my cat is the one thats bad. plus that o2 sensor was just installed last month
Old Jan 30, 2007 | 10:38 AM
Tha one's Avatar
by tha way wut tha cel mean
Old Jan 30, 2007 | 10:49 AM
DonHugo's Avatar
CEL check engline light
aka SES Service engine soon
Old Jan 31, 2007 | 01:38 PM
Tha one's Avatar
went to autozone this morning and put it on the computer reader it read that my rpm is high they said it could be my idle air control so im going to adjust it in a view and hopefully that solves the problem.
Old Jan 31, 2007 | 01:44 PM
Ralliart Lancer's Avatar
If you are going to buy the rrm headers, make sure it comes with the CEL eliminator because the rrm headers alone will just trigger the check engine light on. hmm...I'm just wondering, did the injector cleaner work a lil bit? Was there any change?
Old Feb 1, 2007 | 05:22 AM
Tha one's Avatar
jus a lil change but i think it was my idle air control that was triggering the problem my idling was high i lowered it to about 600 to 700 rpm reseted my battery and cel is off so hopefully that was tha problem. still getting some jumping in my idling so now got to figure out y the idle is jumping.
Old Feb 5, 2007 | 04:33 PM
Tha one's Avatar
cel is off but stl gettin jumping at a stop idle jumps betwwen 600 and 800 rpm dnt knw wuts stl making idle jump at a stop
