Limiter on 08 GTS????
Old Jun 3, 2007 | 12:48 AM
egk-69's Avatar
Originally Posted by cruzzrr
Hey guys...
Was out on back roads today and for the first time "Pushed" her a bit...
Problem is, the engine seemed to be limited to about 6500 RPM???? WTF??
Anyone know how this can be changed?
wow welcome to the FUEL INJECTED CARS ERA
have you ever before drive a non carburated vehicle??
Old Jun 3, 2007 | 12:53 AM
egk-69's Avatar
I'm sure it can handle much more... and if that's the case. why make the tach up to 9k (or whatever it is)? and why set the redline 6500??
why not?
I have a fair answer for this, If somebody make a ECU for the car, and you put some parts on the car (cams, upgrade the head, pistons ......) you can REV the car higher, so If mitsubishi make the car with the tach , that only have from 0 to 6.5 K, then you will need an aftermarket RICER RPM gauge so you can read the RPM.
So thats why manofacturers (or what ever its the word hehe) make the tach to 2K more than the red line
I cannot believe this
DUDE did you have a car before??
Old Jun 3, 2007 | 02:55 PM
otter's Avatar
EvoM Administrator
Originally Posted by Blacksheepdj
NO.
Please read what I asked. The stock redline for the 4B11 is 6500rpm. My car seems to hit redline at 6000rpm. I'd like to know why my car redlines 500rpm before it should.
Will your car rev to 6500 when in neutral? I'm wondering if there's a quirk with the CVT transmission models. Do cars with the MT have the same issue?
Old Jun 3, 2007 | 04:09 PM
RJRR's Avatar
I tested mine out last night. 2nd gear with M/T and it rev'd to 6500K. Maybe something to do with the CVT, but I can't remember the revs when I test drove the CVT.
Old Jun 3, 2007 | 04:18 PM
Sithlord9849's Avatar
Well, I have the CVT and mine redlines at about 6,000; Also I've gotten my car up to about 120 MPH, won't really go anything above that. Just wanted to share my findings.
Old Jun 3, 2007 | 04:27 PM
redevoboy's Avatar
NO.
WOW! Slow down there buddy! I was talking to the OP. NOT you.
Old Jun 3, 2007 | 04:55 PM
DoHBoY's Avatar
Yeah i got mine to 120 also, after like 100 it slowly slowly accelerates. Black, its gotta be something with the CVT because mine limits at 6k too.
Old Jun 3, 2007 | 07:42 PM
ViperF16's Avatar
tru, mine does the same thing. something with the cvt must be holding it back.
Old Jun 3, 2007 | 08:10 PM
Blacksheepdj's Avatar
Thanks for the info, folks. I guess I'm just surprised that doesn't mention that. They just say "redline is 6500" in all the press materials.
Otter - no, I'll try freereving it tomorrow and report back.
Old Jun 5, 2007 | 11:47 AM
ViperF16's Avatar
i doubt the car will rev to 6500 in neutral, but hell i don't know
Old Jun 5, 2007 | 12:42 PM
grandroyal's Avatar
was 120 its max?
Old Jun 5, 2007 | 01:05 PM
Hawkeye's Avatar
Well I've only had mine to about 100 so far, but the dated 5MT tranny doesn't seem to have a problem getting there (and probably further).
As for the CVT redlining at 6k, I dunno. It almost makes sense to me. When would you, whilst driving an automatic transmission, really need to push it past that? It's not like you're needing extra revs to offset shift time - and also, good possibility that revs higher than that could cause undue stress and premature wear of the belt.
Old Jun 5, 2007 | 01:44 PM
ViperF16's Avatar
good point. the cvt wasn't really made for 'racing'. so no need to redline, i'm sure its just a safetly feature for the car.
Old Jun 6, 2007 | 10:03 AM
4500rpm limit in both neutral and park. So much for that test!
Old Jun 7, 2007 | 12:39 AM
ViperF16's Avatar
who would have thought
