Questions on Koyo radiator!
Old Jun 4, 2007 | 05:33 PM
kungfugirl's Avatar
1) Does the radiator made for the evo fit the base lancer as well? I have heard it does with NO modification, as per omar, and i have seen it on kontradictions ride as well (old school i know)
2) Does anyone make hoses for us, I know we can use the lower evo hose but the top one is totally diferent.
3) Will our fan assembly fit the back? I have a slim fan for the ac side but the drivers side fan i will need to keep on there, at least for now.
4) Where can i get one for under 380$, i want the racing edition not the oem replacment. This is the "R" version.
Old Jun 4, 2007 | 09:04 PM
KillahB's Avatar
1.) Lancers have more hood clearance than Mirage coupes and it 'fit' in my coupe. I had to lower my latch to get the hood to close because of the long neck but I dont think that woudl be a problem on the lancer.
2.) When I had it, I was using a 2G upper radiator hose and it fit perfectly.
3.) Dunno.
4.) Where can yo uget a replacement fan assembly? or radiator? If you can find an OEM Evo IV - VI, they are a direct fit with the current hoses as well.
Old Jun 5, 2007 | 06:51 AM
omarboy25's Avatar
evo koyo rad will fit i installed it successfully....
just get aftermarket hoses for it you just have to cut
to fit...if i recall i got my radiator hose from hose techniques
just get an aftermarket fan also our stock fan sucks
especially if turbod
Old Jun 5, 2007 | 07:06 AM
omarboy25's Avatar
i lied its not hose tech....
go to www.coolflex.com for rad hoses they are so good
i was getting leakage on the stock hose
hope this helps....here is some pics and schoose your colors
also its been so long i forgot the inlet size
there is no kit you just have to buy an upper and lower
hose....
https://www.evolutionm.net/forums/sh...d.php?t=233849
Old Jun 5, 2007 | 10:35 AM
kungfugirl's Avatar
Will the radiator fit with the stock hoses?
do you need an aftermarket radiator cap? i keep hearing this.
also if i just want to run the stock fan on the drivers side for a couple weeks till my fan from spal arrives, does it have bolt holes for it?
thanks for help guys.
Old Jun 5, 2007 | 10:50 AM
omarboy25's Avatar
since its been a while i honestly cant remeber...i believe it did...
but why install the factory fan back and then the spal ...i reccommend
install all at one time....with the new fan it should come with those
plastic rods that go through radiator...stock cap does fit
Old Jun 5, 2007 | 10:54 AM
omarboy25's Avatar
keep in mind my setup is fully custom
i didnt do radiator with my RRM turbo kit
this was my most recent mod on my T3T4 setup
with custom mani
evo8tanner
11
Feb 4, 2017 08:32 PM
BrandonIX
15
Jun 12, 2016 08:17 PM
Junaid K
19
Jun 9, 2016 08:58 PM
utggevox
Jun 10, 2012 04:30 PM
MrB
May 23, 2006 04:24 PM
