How-To : Port a stock Intake Manifold
Old Jun 5, 2007 | 12:40 PM
Walkingchaos's Avatar
Ok I know there is another thread on here about how to remove your IM and TB so IM just going to stick to the porting process. For all of you who think you cant port your own IM, youre wrong. A kindergardner who can draw inside the lines could port an IM. So here we go.
First remove your Intake Manifold :
Next clean the hell out of it. There is going to be alot of nasty black and brown stuff coming out. Youre going to want to buy an intake manifold and throttle body cleaner from an auto parts store.
You can actually place the IM in a wash sink, or outside and flush it with water when youre done with the cleaner. CAUTION !!! wear safety glasses and do this in a well ventilated area, that cleaner is nasty stuff and the manifold has a way of shooting it back at ya.
Next step, buy an IM gasket and place it over the IM where it would go in the car, hold it in place by putting a few bolts through the holes as you would on the car. With a paint pen or big sharpie fill in the metal that shows inside the holes of the gasket. Should look like this when youre done.
Ok, now youre going to want to set some blocks up so the IM sits solidly on your work bench. Now get your dremel and a supply of grinding bits. I used 3 or 4 different sizes untill i found one that worked for me. They have tons of sizes so just pick one that works for you. These are the types of bits they use for sharpening chainsaw blades mostly. Have a can of WD40 ready to go, youre going to want to keep spraying the bit and the manifold to keep heat down and keep the shavings flushing away.
You want to keep removing material slowly untill all the black area is gone (see above) and you want to go back into the manifold as far as you can (2 -2.5 inches) KEEP SPRAYING WD40, trust me it sucks if you dont.
When you are all done go back and use alot of the cleaner again. You need to get all the shavings out. alternate between cleaner and hot water flushing. I also found that taping a rag to the end of a stick or thick wire and then stuffing it down the IM helped free things up to be flushed out.
Should look something like this when youre done and cleaned out.
Now re-install.
Hope this was helpful. If anyone wants to try this out Ive got a stock IM ill sell for 85$ shipped. This way your car doesnt have to be down while you work on the IM.
Old Jun 8, 2007 | 10:59 AM
wOZrally's Avatar
hows the difference?
Old Jun 8, 2007 | 11:02 AM
crypto's Avatar
Former Vendor
^+1, is it worth the hassell?
Old Jun 10, 2007 | 05:46 AM
iufan4lifeul's Avatar
I did it with mine. Given the only thing I did was port the runners as I am using stock throttle body. I noticed no difference whatsoever.
Old Jun 10, 2007 | 08:56 AM
SLVROZ_03's Avatar
This mod, along with porting the head, are most noticeable when boosted. N/A...not so much; but it does help.
Old Jun 10, 2007 | 05:09 PM
ported the IM and used an RRM ported throttle body. got rid of any lull in acceleration there might have been. gain was maybe a horsepower or two/ Its more about the power curve then the gain.
Old Jul 21, 2007 | 09:19 AM
Green_Bandit's Avatar
Cool man. If I ever get some extra cash and I find a junked Lancer I might try it. But I'd have to buy a dremel unless I can rent one...
I wish we had some really good shots of an RRM one to compare...
Anyone know if they also did just the runners?
Old Jul 24, 2007 | 10:33 AM
Wallesasuaz's Avatar
Wasn't this Stickied a long time ago?
IF anything, MODS Stickie this!
Old Jul 24, 2007 | 10:51 AM
blaze_125's Avatar
great write up
Old Jul 24, 2007 | 05:37 PM
Frankracer88's Avatar
sounds like a good project. I might have to give it a try
Old Aug 20, 2007 | 12:36 AM
bagice's Avatar
A tip I used for holding the IM in place was leaving the support bracket on the IM and c-clamping the bracked to the work bench.
Old May 20, 2008 | 02:10 PM
jonny2086's Avatar
look like alot of work but if i can get an intake manifold for cheap i will try it and see what kind of gains i will get.........nice pics
Old May 20, 2008 | 09:10 PM
krnzzang84720's Avatar
I did this two years ago!!
bought a mani from junk yard for $65 shipped
took it two to complete porting!!! (did little by little)
Definetly WORTH IT!!!!
makes mean noise after 3.5k rpm!!!! must do!!!!! very nice throttle increase!!!
CAUTION:When you buy the mirage manifold, make sure it has the brake booster nipple in the back of the manifold, I believe you need 1997+ manifold!!!
Old May 20, 2008 | 09:39 PM
ODSevo8's Avatar
nice writeup
Old Nov 1, 2008 | 06:02 PM
OZking425's Avatar
Would it be worth doing this procedure over buying RRM's IM to save money?? or does rrm's IM blow it outta the water??
