throttle body
Old Jul 5, 2003 | 01:15 PM
nightrider4's Avatar
Question throttle body
is the RRM throttle body worth buying. It seems pretty steep for only a 5% increase in HP. What are owners thoughts?
Old Jul 5, 2003 | 02:43 PM
agsmooth84's Avatar
It depends if you wanna go all out or not. Some people just stick with intake and exhaust. Others like myself get intake, throttle body, header, test pipe, and exhaust. Just depends how much you wanna do.
Old Jul 5, 2003 | 06:27 PM
ghostrider's Avatar
Well put. As for the price/hp gain, yeah, it's a bit steep, but only if you're interested in just basic boltons like intake and exhaust.
Look at it this way: the whole point of getting other mods like an intake/header/testpipe/exhaust is to free up airflow. Well, after getting an aftermarket intake, the next cause of restriction in airflow is the throttle body.
Old Jul 6, 2003 | 06:10 AM
ksiebert's Avatar
Is it an actual Lancer throttlebody that has been ported and polished, or is in an actual aftermarket throttlebody?
If it is the stock one, you can easily port and polish it yourself with a simple dremmel tool.. I've done it for another car that I had, with great results..... Save some cash that way..
Old Jul 6, 2003 | 10:52 AM
ghostrider's Avatar
It's the stock throttle body, bored out an extra 5 mm.
Old Jul 7, 2003 | 12:16 PM
blaze_125's Avatar
Don't give me any idea you ... To bad, it's too late... now I wanna do that But I'm too chicken to do so. Does it have to be perfectly even or is there an "error margin". If it's not too hard and complicated, it might be a great project.
Old Jul 7, 2003 | 12:18 PM
blaze_125's Avatar
I keep looking at this picture and I still can't figure something out. Probably cause I don't know enough about boring a TB.
Is the TB plate the same or is it a bigger one? Do they bore only before and after the plate?
Old Jul 7, 2003 | 02:23 PM
pjal84's Avatar
The butterfly is a complete replacement that is, gee, 5mm bigger.
Old Jul 7, 2003 | 02:55 PM
TurboZ's Avatar
wait till the 2.4 comes out which should ahve a bigger tb and it may be a dirrect bolt on. that is waht we did for the 300zx. we got one off a 240sx and it worked great. just a though
Old Jul 7, 2003 | 03:01 PM
fkrzo's Avatar
5mm is alot for a forced induction setup
Old Jul 7, 2003 | 03:16 PM
HobieKopek's Avatar
I'm pretty sure it's 4mm, not 5mm. I could just be remembering incorrectly though. As for the 2.4l tb working, that's no guarantee it will cross models without modifications.
Old Jul 7, 2003 | 03:21 PM
Guru_Del's Avatar
hell if you want to go extreme RPW says they have a 70MM tb. that is 20MM bigger than stock
Old Jul 7, 2003 | 03:26 PM
HobieKopek's Avatar
Your MAF is a bigger restriction than your TB last I checked.
Old Jul 7, 2003 | 03:33 PM
Guru_Del's Avatar
i agree whole heartedly. but there arent too many easy fixes for that right now. yet
Old Jul 7, 2003 | 03:40 PM
HobieKopek's Avatar
E-manage and MAP sensor or ems and map sensor. Ya only need one solution.
Anywho, I'm getting off topic. Consider me unhijacking this thread.
