Alternator
Old Sep 18, 2007 | 11:41 AM
Mirage2.0's Avatar
Alternator
How many wires goes to the alternator itself? Are ther any plugs?
Old Sep 18, 2007 | 11:46 AM
wickdaddy's Avatar
search... here's a install for ya as long as you are posting in the right forum (Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Tech) if not, disregard my post
Old Sep 18, 2007 | 12:45 PM
Mirage2.0's Avatar
Is it true that if you have battery light on and if you unplug the connector from the alterantor, the battery light should go out and that would mean that the alternator is fine. If the light stay on the alternator is bad.
What do you think about that?
Old Sep 18, 2007 | 07:33 PM
wickdaddy's Avatar
i don't know for sure, but when thinking about it... if the light is on, that indicates that the battery is low (less than 12v), so unplugging the connector from the alternator shouldn't effect the light at all because the light kicked on in the first place because the battery was less than 12v. the alternator just recharges the battery after 'juice' is used in the battery...
Old Sep 19, 2007 | 06:28 AM
Mirage2.0's Avatar
My bad. You are right. It's other way around. If the battery light would be go off then that mean that alt is bad.
Topher6564
Apr 25, 2013 04:44 AM
kaftan
Oct 28, 2009 08:51 PM
thebigt
Lancer Engine Management / Tuning Forums
Apr 28, 2009 06:04 AM
kmxxbadboy
For Sale - Miscellaneous Automotive
11
Dec 31, 2008 10:21 AM
davids2004
Lancer Engine Tech
Oct 12, 2006 02:37 PM
