watch this video
Old Nov 20, 2007 | 10:41 AM
crypto's Avatar
Former Vendor
bump.
pulled off the filter, makes the same sound. So i think it could be something in the MAF
Old Nov 20, 2007 | 11:07 AM
WangMan's Avatar
Sexual Favors still for sale?
I had to do it. I have no idea what's wrong but good luck with the troubleshooting. Feel any difference in performance since this has been happening?
Old Nov 20, 2007 | 11:10 AM
crypto's Avatar
Former Vendor
no difference in performance as stated in my orig post. After i cleaned out the EGR valve i actually noticed a little more pick up
Old Nov 21, 2007 | 08:34 AM
lancerrally45's Avatar
its def. not the mass airflow. cuz that just meters how much ait is going into the engine so it can put in a certain amount of fuel.
i wonder if your egr is stuck open, cuz i believe that sensor puts exhaust gas back into the engine. maybe your hearing that. how much does it cost for a new egr? if its not to much. try replacing it
Old Nov 21, 2007 | 08:37 AM
crypto's Avatar
Former Vendor
ok well this morning i messed with it all some more. The sound is actually coming from inside the manifold somewhere. So i sprayed some cleaner in there and scrubbed it a bit. Then reset the ECU. It seems the noise has gone down quite a bit, i had to lift the hood to hear it. But it is still there a little
also the EGR costs $100'ish. This all started when i removed my stock one and cleaned it. But if it was damaged, i would know, there would be CELs and idle problems. I have neither
Old Nov 21, 2007 | 10:16 AM
that is true.
and thats expensive
id say leave it
Old Nov 21, 2007 | 12:58 PM
kungfugirl's Avatar
buy some seafoam.
Old Nov 21, 2007 | 01:22 PM
crypto's Avatar
Former Vendor
i use seafoam regularly. Every other oil change. I have to change my oil this weekend so i will use some then.
But i've been driving my car around some more today and the volume of the sound has dropped a decent amount. So i will give the intake manifold a hard core cleaning on saturday
Old Dec 7, 2007 | 08:31 PM
mrtrunks's Avatar
So did you ever find out what the wooshing sound was??
I only hear the ticking sound once and that because i have an oil leak.
Old Dec 7, 2007 | 08:36 PM
crypto's Avatar
Former Vendor
nope. never figured it out. Although i cleaned out the intake manifold and made it significantly quieter.
plus i have a new issue. When i go in park, my revs go up and down between 700 - 1000 rpm's, only after i've been driving for a while.
My EGR valve is probably busted somehow. So i will replace it eventually. I'm not to worried about it though cos my car is running great. So i will do it all when i install the turbo
Old Dec 8, 2007 | 10:15 AM
Jehuty's Avatar
In all the vids, I see ur SES light on, I thought u said it wasn't on, maybe I'm not lookin at the right thing, but I do see it
Old Dec 8, 2007 | 10:48 AM
at start up it tests all of your warning lights to make sure they are still working so you prolly do see it. but then it goes off after 3 seconds.
