opinion on lancer mod
Old Nov 29, 2007 | 02:55 PM
Geo_lancer's Avatar
i have a oz o3 rally manual. i know how the lancer suxs N/A. I read coutless post regarding this. But here in PR the mirages move good, they are mirages that are in the 15's with the bolt on's w/o internal work but with a shave head and messing with the timing and fpr. I read a post from pr that a guy said putting the mirage 1.8 ECU, bc with the stock ecu we cant mess with the timing. ( i am trying to translate what he said) he also said someting bout the piston that the mirage one are better, that the lance guys should consider replacing them.U guys think by doing the ecu 1.8 swap the lancer will respond better? also shaving the head, that increases compression? is this a good mod for the lancer?
http://carrito.net/board/archive/ind.../t-120205.html
this is the link, but its in spanish.
Last edited by Geo_lancer; Nov 29, 2007 at 02:57 PM. Reason: clarify typing issues
Old Nov 29, 2007 | 03:23 PM
lancerrally45's Avatar
higher compression is good for n/a applications. as far as the ecu swap. why. you can tune with evoscan and ecu flash, that way you can adjust the timing and fuel maps the way they need to go.
pistons are fine unless you want high boost. they will hold 8 psi just fine on a good tune. even 10 on a great tune. (mine like to spike at 10)
Old Nov 29, 2007 | 03:32 PM
TouringBubble's Avatar
On the '02 - 05 Lancer you can tune the stock ECU with ECUFlash as mentioned above. Changing the head and ECU seems like overkill to me. Is the 1.8 in question a 4G6X engine or a 4G9X?
Old Nov 29, 2007 | 05:18 PM
Geo_lancer's Avatar
oh ok i c, the ecu flash wold seem like a better option, i was just trying to see if the lancer n/a could run as good as the mirages n/a here at the island.
its the 4g93
by the shaving the head, how much will the compression rise( i guess it all depends on how much u shave), but still aint sure? a pal of mine is gonna do it on his 4g93, but i havent read anyone who's done it here. is it worth it? idk much in that aspect
Old Nov 29, 2007 | 06:14 PM
when you start shaving a head you have to think about a couple things. how much timing its going to retard your cam and how close the valve are going to be from hitting the pistons. i found on a website that a decking of .020" would retard a cam about 1-2 degrees. you could get an adjustable cam gear.
but as far as how much compression you would get. im not sure, ill check on it and get back with everyone
Old Nov 29, 2007 | 06:20 PM
i would say your best bet is to call a machine shop. haha
Old Nov 29, 2007 | 08:44 PM
Geo_lancer's Avatar
lol... yea, i guess ur right.
Old Nov 30, 2007 | 12:36 PM
Also, the 4G93 is a direct injection motor.
Old Nov 30, 2007 | 12:42 PM
ambystom01's Avatar
The 4G93 is direct injection? That's weird since the 4G94 can use the same intake manifold, same head, and I think the same fuel rail.
Old Nov 30, 2007 | 12:48 PM
kungfugirl's Avatar
its direct injection?
Old Nov 30, 2007 | 01:51 PM
Originally Posted by WikiPedia
The 1.8 L (1834 cc) 4G93 is also available in both SOHC and DOHC versions. Turbocharged variants are also produced. The 4G93 was the first modern gasoline direct injection engine on its introduction in August 1996, and Mitsubishi produced over a million GDI engines. The SOHC 4G93 provides 86 kW at 6000 rpm and redlines at 6500 rpm
Sorry, I read it incorrectly. Not all of them are direct injection.
Old Nov 30, 2007 | 07:11 PM
KillahB's Avatar
Yeah the USDM mirages are all non-GDI.
Keep in mind, the mirages / technicas way way less than their Lancer cousins. When I weighed mine in at a weigh station a couple years ago, it was at 2440 lbs.
Live4Redline
Lancer Engine Tech
19
Jan 9, 2017 09:55 PM
imalancerman
Lancer Troubleshooting
30
Jul 23, 2009 04:28 PM
92G2GSTurbo
Lancer Engine Tech
Jul 12, 2007 09:18 AM
Mirage4g93
Northwest Region
94
Apr 26, 2007 01:41 PM
Melaz425
Lancer Engine Tech
May 10, 2004 03:03 PM
