More Products
Old Dec 14, 2007 | 09:15 PM
resolutionny7's Avatar
More Products
Hey guys check it out these Guys speed corps now have spark Plugs from Denso and Ngk. Also there carying the Fujita SRI.
http://stores.speedcorps.com/Categor...+2008%3AEngine
http://stores.speedcorps.com/Detail.bok?no=301
Check it out guys
Old Dec 14, 2007 | 10:22 PM
cRc`22's Avatar
would spark plugs help the starting problem?? its only happened to me once but i dont want it to happen again..
Old Dec 15, 2007 | 06:06 AM
evo_soul's Avatar
hard to say, i think they are already irridum. I would say not by much. The reason your car isnt starting is due to a fault in your start up sequence. I have had prefectly good start ups aborted 1 1/2 seconds into it. I have had it explained to me that the car is just more fussy when it comes to starting up compared to cars in the past.
Not sure if the tech was pulling my leg. but the next time it happens, turn your car to the on position for 5 seconds or so, then crank it. It should start if not get it on video and bring it to your dealer if its a persistant issue. it happens to me once a month
Old Dec 15, 2007 | 08:00 AM
fuz_dnz's Avatar
Hasn't happened to me a single time. Then again my car only has 3000 miles.
Old Dec 15, 2007 | 08:43 AM
Blacksheepdj's Avatar
I hope not. I don't want to be dropping $60 per plug change. I have one coming up in 3k miles!
Old Dec 18, 2007 | 10:55 AM
Deepside's Avatar
Hummm when my fuel pump had a link in my volvo, I needed to turn the key for 5 sec to let the pressure build up in it, then start. If not, It was taking like 10 secondes to start (really hard on the starter and battery).
So I don't know about the lancer problem since I don't have it, but if you need to put the key to on before I don't think (without being a mecanics) that the spark are the problems..
Old Dec 18, 2007 | 11:30 AM
nj_08_gts's Avatar
08 Lancer spark plugs are iridium, so start saving your pennies
Old Dec 18, 2007 | 11:55 AM
evo_soul's Avatar
you can allways cheap out and throw the Platnium 4+ Bosch plugs in hehe
they worked fine in my other car
Old Dec 18, 2007 | 01:58 PM
FinestSoldier's Avatar
i have the pulstar plugs. i was the giny tester
Old Dec 18, 2007 | 03:24 PM
NGK FR6EI, after checking the manual.
$11.71 each at NGK.com
You can also get a set of Denso iridiums from Speed Corps. for $50.
Old Dec 18, 2007 | 11:57 PM
ProRCRacer's Avatar
Woh, speedcorps has carbon fiber trunklid. Kickass! That's what I'm talkin' about! Now, someones just gotta make some cf doors, Yeah!
