what injectors u guys using
Old Feb 7, 2008 | 01:32 PM
customlancer's Avatar
im am wondering what upgraded injectors are being used on moded 02 lancer engines (4g94).. And where u ordered them. I have reached the limit on my stock ones.. im going to upgrade to a stage 2 cam of some sort. Any info with set ups would be helpful
Old Feb 7, 2008 | 01:39 PM
senate6268's Avatar
440cc injectors from a WRX fit with longer fuel rail bolts. Also, 460cc injectors from an older RX-7 work. Your other option would be RC Engineering injectors around 325cc.
Old Feb 7, 2008 | 02:02 PM
ambystom01's Avatar
How have you reached the limits of your stock injectors? Are you turboed?
Old Feb 7, 2008 | 02:19 PM
SLVROZ_03's Avatar
I believe this is his current mods list:
Mods
RRM Intake Manifold
RRM Throttle Body
RRM Fuel Rail
RRM Header (Check Engine Light on)
2 1/4 exhaust
Test Pipe
Old Feb 7, 2008 | 02:21 PM
ambystom01's Avatar
Yeah he doesn't need new injectors, he's barely making more than stock power.
Old Feb 11, 2008 | 11:34 PM
styleN_oz's Avatar
^agreed, same mods except fuel rail..I have no check engine light, my car is running like the day I bought it new in 02.
It was nice to know what I can use when I change them though.
Old Feb 17, 2008 | 08:29 PM
BlackOZLancer's Avatar
yeah he is going to need a lot more power than that for bigger injectors
Old Feb 18, 2008 | 06:12 AM
Mirage2.0's Avatar
When I was NA then I used 275cc galant injectors. They look the same as ours just different color (yellow). It's way enough for NA application.
BTW: now running 460cc rx-7 injectors.
