Spark Plugs
Old Jun 9, 2008 | 07:37 AM
TougeOZ_04's Avatar
Spark Plugs (new ?)
Ok i've done a search and read many post.
i've never replace spark plugs and wires!
i Have a 04 Lancer oz
i have just picked up
NGK IX iridium
Part #BKR5EIX-11
gapping set at .044"
NGK Premium wire set
Part# ME96
i've read a couple of post where people have set the gap to .036 and .034. then i read on All you need to know: SPARK PLUGS! that you shouldn't have to regap Iridium
so can i just install the plugs as is with double checking the gapp. or should i set it to a closer? i really don't want to mess anything up because it's the only car i have!
also i'm going to be hitting 40,000 here soon and i'm still on stock spark plugs and wires is this bad?
Old Jun 9, 2008 | 07:53 AM
Kurt's Avatar
NGK IX iridium
Part #BKR5EIX-11
Part# ME96
What does Mitsubishi suggest to set the gap at?
40000 miles on the stock plugs and wires is not bad. I had close to 60000 on the stock plugs and wires when I got rid of my car. I checked them every 3rd oil change just to keep an eye on them.
Old Jun 9, 2008 | 08:07 AM
TougeOZ_04's Avatar
i have actually never checked them and i know i should, LOL
i actually don't know, i will have to check the manual to see
Old Jun 9, 2008 | 11:59 AM
TougeOZ_04's Avatar
anyone else?
Old Jun 9, 2008 | 12:33 PM
ambystom01's Avatar
Check the manual.
Old Jun 10, 2008 | 05:57 AM
TougeOZ_04's Avatar
does adding aftermarket spark plugs and wires give u less MPG???
Old Jun 10, 2008 | 10:48 AM
ambystom01's Avatar
No.
Old Jun 17, 2008 | 12:29 PM
mcgarvey's Avatar
The gap is specified on the little tune-up sticker on the under side of your hood. I don't know exactly but .050 should be good. Don't go smaller. Mitsubishi specifies 60,000 miles for plug replacement and for Cali spec vehicles, something crazy like 110,000. Sure the plugs may still be ok but have fun trying to unscrew them from the head after they've been in there all that time.
Old Jun 20, 2008 | 12:28 PM
ericmcdaniel's Avatar
i didn't change out my stock plugs till around 110-115k miles. had no problems with them.
Old Dec 12, 2008 | 07:06 PM
clifton's Avatar
Exclamation
You should not go bigger than .040, it's a fact.
Deanooo
Aug 25, 2016 05:17 AM
kambodianboi
Oct 6, 2010 08:13 PM
evo_andy
Jun 30, 2009 06:47 PM
luischav3z
Lancer Engine Tech
Jan 11, 2009 10:21 PM
donduck
Lancer Engine Tech
11
May 23, 2005 06:48 AM
