anyone on the RPW stage 2 cam
Old Nov 1, 2008 | 08:30 PM
OZking425's Avatar
Is anyone out there running RPW's Stage 2 cam on their N/A 4g94? Turbo too..
im considering getting them, and curious about the gains/results from them.
also, anyone know how they compare to RRM's stage 1 cam?
thanks
Old Nov 1, 2008 | 09:51 PM
4g94T's Avatar
I have stage 2 turbo version.
Haven't installed it yet because I will be doing it all at once with my rebuild.
It's obviously a wilder cam than RRM because you need upgraded valve springs
Old Nov 1, 2008 | 10:07 PM
OZking425's Avatar
for sure for sure...
well let me know how everything comes together. im interested.
did you get the venier cam gear with it too? i cant remember if RPW said they were required with the stage 2, or if it was just for better results.
Old Nov 1, 2008 | 10:08 PM
OZking425's Avatar
Old Dec 15, 2008 | 02:30 AM
Mitsiman's Avatar
Vernier camshaft gear is not necessary, but if you do use one then there are large gains to be had with them, especially as it will really allow you to tune the car better by moving your powerband around.
Old Dec 15, 2008 | 09:22 AM
sykou's Avatar
Im running the stage 2 with a custom 16g setup. Using 440cc injectors and the idle is kinda rough. Not shake your whole car around kind of rough but i gotta say it idles kinda like a harley. Have the findanza cam gear but i have it set to stock tdc still. The crank is retarded three degrees as factory instructions if i remember correctly so I guess you would be able to advance the cam gear a bit. Dont really see the need to though because you can mess with your timing using ecuflash....
4g94T
Lancer Engine Tech
18
Nov 3, 2008 09:01 PM
firechicken
Lancer Engine Tech
11
Mar 25, 2005 04:52 AM
Hotshot940
Lancer Aftermarket Forced Induction Tech
26
Mar 16, 2005 11:17 AM
jmw32123
11
Aug 3, 2003 09:35 PM
fury656
Lancer Engine Tech
38
May 13, 2003 12:17 PM
