WET/DRY Nitrious Systems
Old Dec 7, 2008 | 10:47 AM
mrblondelv's Avatar
Soo, does anyone know what would be a better system for your car (engine wise), a WET system or a Dry system ?
And would it be feasable to do this route, because of not having money for a turbo
Old Dec 7, 2008 | 11:11 AM
def1's Avatar
wet i think is the best for small n/a cars but im not sure i might be backward on this. Either way I dont think you'll be able to run more than a 50 or 75 shot of nitrous. I also dont think its worth the money.
Old Dec 7, 2008 | 11:18 AM
mrblondelv's Avatar
Cool, thanks for your response
Old Dec 29, 2008 | 06:11 PM
jason_hann53's Avatar
what injen exhaust do you have? the headerback or the axleback?
Old Dec 29, 2008 | 06:26 PM
lancerman360's Avatar
If you have to ask which is better "wet or dry" then its obvious you have not done enough research. Wet systems also add fuel in with the nitrous to keep the air fuel ratio correct, dry systems do not and therefore make your car run lean while you are spraying.
Do your research. If you cant afford a turbo, I doubt you can afford major engine repairs.
Edit: However my friend has a dry setup on his 2.2 N/A ecotec spraying a 50 shot and his car runs just fine. I just dont think its worth the risk to run a dry setup. A wet system may be more expensive but its safer and I think you will see better power gains.
Old Dec 30, 2008 | 05:54 PM
mrblondelv's Avatar
This is what I have as an Axle Back Injen Technology Super SES Polished Stainless Steel Rear-Section Exhaust System w/ Titanium Tip
Old Dec 30, 2008 | 08:32 PM
LuDa's Avatar
def want to run a wet..especially on these lancers..i wouldnt do anything past a 75 shot on stock internals
Old Dec 30, 2008 | 08:38 PM
mrblondelv's Avatar
Thanks for the info on that, I'm still debating on the Nitrous, and Turbo, I just don't wanna do a Turbo, then my tranny blows out.....
Old Dec 30, 2008 | 08:53 PM
ambystom01's Avatar
If you go with nitrous, you stand just as much a chance of blowing something up.
AutoMotoSports
Automotosports - Illinois
30
Aug 5, 2018 10:55 AM
awdordie
Sep 19, 2011 12:38 PM
hatethefuzz
Lancer Engine Management / Tuning Forums
May 9, 2008 08:56 AM
javis06ralliart
24
Jul 26, 2007 06:45 PM
TOMEI EVO 7
Sep 14, 2003 10:51 AM
