Cams.
Old Feb 24, 2009 | 11:57 AM
OZ Rally's Avatar
Originally Posted by ThunderOZ
How much of a difference would think it would make with a boosted motor though?
It wouldn't make a difference since the valve timing is only off by 4 deg. Both the intake and exhaust valves are open for the same amount of time. It would be better to get a more aggressive cam that has higher lobes. That way the valves are open for a longer period of time. You need to be careful with the extra lift so the valves don't hit the pistons.
Old Feb 24, 2009 | 12:01 PM
OZ Rally's Avatar
Originally Posted by davidmitsusrock
How easy is it to install this? take off the timing belt cover, unbolt, bolt on new one? it cant be that simple...anyone done this?
It should be pretty easy. Just take off the belt cover, take off the timing belt, unbolt the cam gear and slide the cam out.
You need to be careful to have the first piston at TDC when taking off the belt and taking out/putting in the camshaft.
Look at the service manual to see the procedure in more detail. ^That's just from the top of my head.
Old Feb 24, 2009 | 06:04 PM
*02Lancer*'s Avatar
do you mean wider lobe's so they stay open longer?(duration) And the 4g93 has a larger duration and it stay's open long and less lift so it does not open as
much.http://www.rpw.com.au/Products/Engin...pec4g93s16.htm
im going off this ^
Old Feb 24, 2009 | 08:35 PM
OZ Rally's Avatar
im going off this ^
Might as well save up and get a stage 2, 3 or a 272/272 cam instead. You're not going to feel a difference with the 4g93 cam.
Old Feb 24, 2009 | 10:48 PM
*02Lancer*'s Avatar
yah im going to use it as a core and try and find someone to regrind it for me :P maybe save some $ will see how it goes.
Old Feb 24, 2009 | 11:05 PM
4g94T's Avatar
dont forget upgraded valve springs from RPW.
mine just shipped out today
i can finally install my stage 2 turbo cam
Old Feb 24, 2009 | 11:31 PM
*02Lancer*'s Avatar
yes those are very important. they dont happen to say/tell the spring pressure on them do they?
Old Feb 25, 2009 | 07:06 PM
4g94T's Avatar
RPW says it can handle high lift cams, send them an email if you're uncertain.
but anything higher than their stage 2 camshafts requires their valve springs
Old Feb 25, 2009 | 07:09 PM
OZ Rally's Avatar
4g94T - When you install your cam make a vid of it. The rough idle makes my girlfriend's panties wet!
Old Feb 25, 2009 | 07:20 PM
*02Lancer*'s Avatar
lol wow ^ what a thing to say
Old Feb 25, 2009 | 07:24 PM
OZ Rally's Avatar
Hey don't you think I'm jealous!?
Wait till I install my cam! There's a reason my windows are tinted. lol
Old Feb 25, 2009 | 10:28 PM
4g94T's Avatar
Haha
Sykou posted a video of his idle, it's not so harsh if you raise your idle to 1k
But the valvetrain noise is even worse
Old Feb 26, 2009 | 10:59 AM
davidmitsusrock's Avatar
If i just put the OBX cam gear on would i need to get new valve springs?
Sorry im still learning alot about these things .
Old Feb 26, 2009 | 11:15 AM
kronic420haze's Avatar
you dont need springs if your changing the cam GEAR its the cam SHAFT that need new springs if its agressive enough. the cam gear is the thing thats on the end of the camshaft that the timing belt goes around
