Cams.
Old Feb 6, 2009 | 10:52 AM
davidmitsusrock's Avatar
Cams.
I saw an OBX cam gear for our cars for like $85 online. Has anyone done this? performance? worthwhile? or?
Old Feb 6, 2009 | 10:54 AM
Evo666's Avatar
Not if you don't have any other things to go with it. ie cam shafts, maybe safc to tune it.
Old Feb 6, 2009 | 10:55 AM
Domolution's Avatar
Old Feb 6, 2009 | 12:39 PM
ThunderOZ's Avatar
You could always just pick up a mirage cam... It's like a stage 1 cam for our car...
Do you plan to boost? Tune?
Old Feb 6, 2009 | 08:40 PM
I would love to boost but probably not due to money. And i wont be tuning either. I would just like to pick up a few hp and maybe a slight increase in acceleration.
Old Feb 18, 2009 | 10:02 PM
Lucas03ES's Avatar
What car does the cam have to come out of exactly? I know it needs to be a 99+, but also I have heard it needs to be from a manual and an LS model? that true or what? Thanks
Old Feb 18, 2009 | 10:30 PM
*02Lancer*'s Avatar
I looked up online and on alldata pro. and it say's nothing about a different cam for manual or auto. I got a auto cam out of a 00 or 01 mirage 1.8L and i am going to check lift/duration on it to make sure but im about 90% sure it does not matter if it's auto or manual.
Old Feb 19, 2009 | 11:35 AM
OZ Rally's Avatar
4g94 2.0L
Intake open 2 deg BTDC
Intake close 58 deg ABDC
Exhaust open 58 deg BBDC
Exhaust close 10 deg ATDC
4g93 1.8L
Intake open 6 deg BTDC
Intake closes 54 deg ABDC
Exhaust opens 54 deg BBDC
Exhaust closes 6 deg ATDC
For you slow people:
BTDC - before top dead center
ABDC - after bottom dead center
BBDC - before bottom dead center
ATDC - after top dead center
Old Feb 19, 2009 | 11:38 AM
OZ Rally's Avatar
So from what I just showed, the 4g93 intake opens 4 deg before the 4g94. But then again it closes 4 deg before the 4g94.
Same for the exhaust side. I'm sure you will not see a significant difference in changing the camshaft.
Old Feb 19, 2009 | 11:41 AM
OZ Rally's Avatar
The camshaft from the 4g93 1.8L from 98-02 are all the same. It doesn't matter if it is manual or not.
Old Feb 19, 2009 | 11:32 PM
Lucas03ES's Avatar
Cool, thanks for the info, i was thinking about giving it a shot since I can find one for like $15 at my local pic-a-part.
Old Feb 20, 2009 | 03:35 AM
OZ Rally's Avatar
Doesn't hurt to try, give it a shot and let us know how it goes.
Old Feb 22, 2009 | 05:28 PM
kronic420haze's Avatar
did you ever try this?
Old Feb 23, 2009 | 06:10 PM
ThunderOZ's Avatar
How much of a difference would think it would make with a boosted motor though?
Old Feb 24, 2009 | 11:33 AM
How easy is it to install this? take off the timing belt cover, unbolt, bolt on new one? it cant be that simple...anyone done this?
