Turbo Exhaust/Muffler on N/A Lancer?
Old Mar 22, 2009 | 12:36 PM
Racecarzz08's Avatar
ive seen on other forums and places it was said that you would get a better sound or possibly even more power than a regular muffler with a turbo muffler or catback turbo exhaust. is this true? can you benefit on a NA motor with a turbo exhaust
Old Mar 22, 2009 | 12:38 PM
evo_soul's Avatar
its impossible to really tell without the data of the exhausts. and the design. I would say no, but that would be an opinion based on not enough info. sorry
Old Mar 22, 2009 | 02:17 PM
4g94T's Avatar
Define turbo exhaust and turbo muffler.
Do you mean bigger piping? Straight through mufflers?
Too large of an exhaust ID piping in a NA car will lose torque and most of the gains will be seen at high gears/speeds
Old Mar 23, 2009 | 12:34 AM
Bladed's Avatar
most turbo exhaust are 3 inch straight pipes with a non restrictive muffler (if there is a muffler). With that kind of design you will lose back pressure which will result in a drop of low end power/torque but you might see a gain in the higher RPMS, but it won't be much of a gain
I'll have to agree with everyone else and say it's not worth it.
Old Apr 11, 2009 | 08:27 PM
englandsemo's Avatar
Currently Running no muffler, with just a straight pipe. Basically a home made version of the Works exhaust pipe. couldn't see spending 300 for a pipe i could make myself. Noticed gains in the top end and the sound is clean when taking off. Almost stock sounding when crusing, just a mild hum. The resonator seems to do the job of keeping me away from a ricey sound. Have been running it for about a week now and i'm very happy with it. Kept the 2" oem echaust size as i felt going bigger wouldn't make sense seeing as the midpipe is only 2" anyway. Also have both cats gutted regardless of the legality i noticed considerable gains from that as well. Did the cats and axle back straight pipe at different times and i def noticed an increase in power with the addition of each.
Old Apr 11, 2009 | 08:32 PM
brndn23's Avatar
^ isn't oem exhaust 2.25"??
Old Apr 11, 2009 | 08:37 PM
i thought so myself, even purchased 2 1/4" when i went to do the axle back but after measuring it i discovered it was only 2"
exhaustfreak
14
Mar 3, 2016 03:18 PM
AJCaron12
Jul 21, 2015 08:34 PM
Lightsaber
Jul 1, 2015 12:10 PM
OyoyOzRally
Lancer Engine Tech
31
Jun 28, 2015 12:57 PM
LovingLancer
Lancer Engine Management / Tuning Forums
Apr 18, 2014 10:06 AM
