new headers, and now stalls
Old May 6, 2009 | 02:05 PM
satanschildrebr's Avatar
Hey everyone, i jsut installed RRM Headers on my 2003 Lancer ES, and now when i stop at red lights or stop signs, the RPM drops to about 300-500, and sometimes stalls. I installed the CEL eliminator on the second O2 sensor like instructed. Does anyone have any clue as to what could be causing this.
thanks in advance
Old May 6, 2009 | 02:49 PM
Shingen's Avatar
Have you pulled your negitive off of your battery for twenty minutes and then reconnected? I had to do that to mine when I did it. It resets the ECU and you shouldn't have a problem after that.
Old May 6, 2009 | 03:26 PM
ambystom01's Avatar
Did you hit or otherwise damage the first O2 sensor?
Old May 6, 2009 | 06:01 PM
i had the battery disconnected the whole time. so i dont think that would have done it.
and as for the o2 sensor being damaged, from what i know about o2 sensors is that if one was damaged to the point where it doesn't work i'd get the check engine light. The stock headers had a pre-cat on them, and the eliminator just eliminates the error for not having that pre-cat anymore. at least that's what i've understood
Old May 6, 2009 | 06:13 PM
Punz247's Avatar
I have OBX headers and my CEL never turned on. Why dont u try and disconnect the O2 and run it under a wheel to clean up some of the carbon and try that before u go out and spend that kind of money. Would anybody know if some Break cleaner would work for the inside? or would that be alil too harsh?
Old May 6, 2009 | 07:23 PM
Did your stock exhaust manifold have a pre-cat on it, and what exactly did you mean by "a wheel"
Old May 7, 2009 | 04:44 AM
blaze_125's Avatar
thanks in advance
Same thing happens to me everytime I disconnect my battery for more than 10 minutes. It will settle with time. It's your ECU re-learning how to work. To not stall at a red light, I just give it a little gas. 100 clicks or so and you'll be good.
Old May 7, 2009 | 06:37 AM
Daedalus2051's Avatar
I had a similar issue when i put in my short ram intake, since i disconnected the battery (as per the instructions) the ecu's memory got wiped and it had to relearn where the idle rpms should be... only took about 45 mins, and/or maybe 20 to 30 miles and then everything was back to normal.
Old May 7, 2009 | 07:27 AM
blaze_125's Avatar
Oh, and while the ecu is learning, make it learn what you want it to learn. Drive the car the way you plan on driving it. I don't know if it actually makes a difference or not, but I figured if the ecu had to learn something I'd teach it harsh conditions
Old May 7, 2009 | 07:43 AM
hahaha nice blaze... in all seriousness that's a good point tho. honestly i'm not sure off the top of my head what the computer in a manual trans learns to compensate with; but i know that in an automatic when the computer is reset it has to relearn the shift points. So if you hammer on the thing and drive like an a**hole (as many jersey drivers do... yes i admit it i can be an a**hole behind the wheel, but only if you **** me off lol) then your car will develop parameters to that kind of driving.
Old May 7, 2009 | 10:10 AM
Punz247's Avatar
I still have the resonator and the cat on my car. Sorry I should of been more detailed but what i mean by "wheel" i meant a polishing wheel to clean up the O2.
Old May 7, 2009 | 10:11 AM
Punz247's Avatar
Also put in gas that u would want to burn in it if thats the case.
Old May 7, 2009 | 11:46 AM
bcollinstex's Avatar
use regular unleaded
our car's ECU isn't a flex fuel system
Old May 7, 2009 | 12:31 PM
alrighty, well i didn't think it would take that long for the computer to relearn everything, if that's the case i have about 20 more miles to go, i've only been driving it to school right now cuz i thought something was ****ed up on it. But i'll wait and see what happens
thanks a lot for the feedback guys.
Old May 7, 2009 | 11:54 PM
Chameleonzero's Avatar
is the o2 sensor that goes to the header connected back up
