Aligning bottom of air filter
Old May 14, 2009 | 05:19 PM
Mitsuman10's Avatar
I recently put a new drop in filter in my lancer and I can not for the life of me, align the bottom of the filterbox. Is there any trick to this? Any help? Please
I feel dumb haha
Thanks!
Old May 14, 2009 | 05:57 PM
brndn23's Avatar
there is really no trick to it, filter should just go right in. Try putting bottom in first then sliding in the top maybe, otherwise, it should be a no brainer. good luck
Old May 14, 2009 | 06:35 PM
glbg's Avatar
I have the same problem, when I first installed my drop I kinda open it too wide and knocked the bottom part of the filter box. Try this...
-Removed the air filter so you can see just the filter box structure.
-In between the filter box when you look at bottom there's kinda a notch. Align the notch then slightly move it forward, push it down a little bit and move it backward until it locks at the bottom.
- Then slip in the air filter back.
I hope this helps.
Old May 14, 2009 | 07:07 PM
Mitsuman10's Avatar
Ah! i got it, thanks you guys
Old May 29, 2009 | 11:58 AM
kingpaco's Avatar
Please tell me where you bought your drop in filter and the part number, I bought one at walmart and it didnt fit,. returned it, .and bought one online at rockauto.com and it didn't fit either,..wtf!
Old May 29, 2009 | 12:16 PM
EngRWW33's Avatar
http://www.knfilters.com/news/news.aspx?ID=1421
Can't get them at walmart. I haven't seen them in stores, although I'm sure that autozone/pep boys can order one for you..
Old May 29, 2009 | 12:20 PM
QwikEVO's Avatar
I had the same problem with my wife's Outlander, which I'm assuming is similar to the Lancer's. Just make sure you line up the bottom and when it sits in there...shove the filter in there...
Old May 29, 2009 | 06:16 PM
glbg's Avatar
7022 Replacement Filter (x1): USD 78.86
2000 Recharge Oil and Cleaner Kit 12oz(Green #2000) (x1): USD 11.04
http://greenfilterusa.com/
Old Jun 3, 2009 | 09:34 AM
mguerrero's Avatar
Custom intake Specs.
Has anyone custom made a short ram intake for the gts? Im currently trying to but i can only find the MAF flange for an evo x. Does anyone know if the MAF sensor is the same for the gts and the evo x?
Old Jun 3, 2009 | 01:10 PM
lancer0220's Avatar
yeah the maf flange for the evo x will fit, i have confimed it with a stock evo x box
Old Jun 4, 2009 | 03:33 PM
mguerrero's Avatar
Yea thanks man! One more question how much would a mandrel bent pipe cost about a foot and a half of it maybe less?
Old Jun 6, 2009 | 08:05 PM
Stuntfly02's Avatar
This really depends on where you go to buy it and the Quality of the steel. Chinese metals are usually cheap and brittle and I'm not sure how they stand up to excessive heat exposure. Get a section of SAE 1020(its a grade of metal) piping and take it to a muffler shop and see if they can bend it for you lol. Good luck with making a custom intake...i know a few people have tried and succeeded.
