Still running rough
Old May 16, 2009 | 09:23 AM
jarred88's Avatar
Unhappy Still running rough
Hey guys, i have a 03 OZ with 117000 miles and a rough idle and ive tried SO much to fix it and i cant figure it out,
i have:
bought a new catalytic converter, [the second one]
new 02 sensor
checked all my intake!
and i have NO check engine light, i just put in the o2 sensor and the engine light went off, any ideas?
Old May 16, 2009 | 11:14 AM
Ozdriver's Avatar
how do the plugs look?
Old May 17, 2009 | 07:26 PM
jarred88's Avatar
there brand new! i bought them recently.
Old May 17, 2009 | 07:43 PM
Ozdriver's Avatar
was it doing this before you replaced the plugs? what did you get for plugs?
have you checked all your vacuum lines? what do you mean by running rough? what is it doing exactly? is it just at idle does it get better or worse at different rpms?
Old May 17, 2009 | 07:44 PM
jarred88's Avatar
ive checked them, it idles slightly rough at 700, then from 800-1100 it REALLY rough and loud, then runs out smooth,
Old May 17, 2009 | 07:47 PM
jarred88's Avatar
it did it when i bought the car, and i went with basic plugs, single prong copper plugs
Old May 17, 2009 | 07:59 PM
Ozdriver's Avatar
did you check to make sure the plugs were properly gaped?
Old May 17, 2009 | 08:02 PM
jarred88's Avatar
i did gap them correctly but it wouldnt hurt to check, any other ideas? ive gone through so many typical fixes
Old May 17, 2009 | 08:08 PM
Ozdriver's Avatar
did u try resetting the ECU yet? its a long shot but easy enough to try..... maybe injectors could be a bit gummed up. there are lots of reasons you could be having this problem its hard to say without being able to see/hear the issue (at least for me)
Old May 17, 2009 | 08:09 PM
jarred88's Avatar
yeah well ive heard of cleaning injectors and stuff but i dont know how to do that kind of stuff. but i havent reset the ECU
Old May 17, 2009 | 08:20 PM
Ozdriver's Avatar
to reset your ecu disconnect your battery for a few mins reconnect and you should have reset.
I would toss can of seafoam in your gas tank next time you fill up to help clean everything out.
could be bad ignition coils? dunno just throwing ideas out there
Old May 17, 2009 | 08:36 PM
jarred88's Avatar
i appreciate it! ill post on the results
Old May 17, 2009 | 08:52 PM
coal's Avatar
Timing belt?
Old May 18, 2009 | 01:55 PM
Ozdriver's Avatar
Originally Posted by coal
Timing belt?
you think his timing could be off? or that his belt could have skipped a tooth? I would think that would cause a lot more problems than what he is experiencing but then again I could very well be wrong.
any updates with your issue?
Old May 18, 2009 | 05:12 PM
jarred88's Avatar
well now im having a slight bit of trouble getting it started. narrow it down?
