Still running rough
Old May 18, 2009 | 05:14 PM
Ozdriver's Avatar
are you getting spark?
Old May 21, 2009 | 01:57 PM
Ozdriver's Avatar
update?
Old May 21, 2009 | 02:10 PM
bcollinstex's Avatar
probably coil packs, but it would probably give you power loss going down the road
at 117k, you really should be doing a complete maint. run through, everything from coolant to ignition, to timing belt
Old May 22, 2009 | 01:54 PM
Jehuty's Avatar
You said that light came on, or it was on and went off? Point blank do you have it on now, if you do get the code pulled and bring it back. Also, just to throw this out there, are you sure your check engine light even works? It might be on and the bulb isn't coming on, either way, we're going to need a little bit more info. When my coil packs went bad my idle wasn't bad, it was when I drove that my car sounded bad.
Old May 26, 2009 | 05:12 PM
bagice's Avatar
I had to do this every once in a while with mine when it started to idle rough. run it down to quarter tank. put a whole bottle of injector cleaner in. run it to 1/8 tank or less. then it would run great. I found the problem stoped when i switched gas stations.
Old May 29, 2009 | 02:04 PM
03lances's Avatar
Dont forget after you do reset the ecu it is not going to want to idle at all until it completes the relearn routine
Old May 29, 2009 | 02:05 PM
03lances's Avatar
I would change the pcv valve too its only a couple bucks and that can create lots of idle issues
Old Jun 1, 2009 | 10:01 PM
jarred88's Avatar
sorry its been a while guys, i really appreciate all the help, ive been having computer trouble so i havent been on,
hen goes
CURRENTLY: the check engine light comes on, then goes off,
the car has ran rough sense i got it so i wouldnt know how much power i should have,
I HAVENT tried injector cleaner, i will tomorrow and post results.
Old Jun 2, 2009 | 05:47 AM
senate6268's Avatar
I would do a compression test to verify integrity in the cylinders before using injector cleaner.
jennz03
Lancer Troubleshooting
Feb 20, 2017 08:15 PM
DSMvsWhatever
May 16, 2010 09:16 AM
havik65203
Feb 9, 2010 08:38 AM
Stormtrooper
Jan 3, 2010 07:28 PM
cfralliart
Mar 13, 2009 08:31 PM
