Valve Gasket Leak, Will This Work?
Old Jun 3, 2009 | 01:05 AM
White_KnightOZ's Avatar
Alright, so I spent alot of time today working on my car, and in the midst I noticed that i have a not so good leak all around my valve cover. There isn't really a Mitsu dealer close, but I went to Pep Boys down the street and they said they can order one for me for like 20 bucks. However, when I went home I started searching around and found a gasket kit for the 4g93, it includes:
+ Graphite head gasket
+ Intake manifold gasket
+ Exhaust manifold gasket
+ Valve cover gasket
+ Viton valve stem seals
+ Camshaft front
+ O-rings
+ Other Small Gaskets
And it says its good for:
1992-1996 1.8L DODGE COLT 4G93 SOHC 16V
1992-1996 1.8L DODGE COLT VISTA 4G93 SOHC 16V
1992-1996 1.8L EAGEL SUMMIT 4G93 SOHC 16V
1992-1994 1.8L MITSUBISHI EXPO LRV 4G93 SOHC 16V
1993-1996 1.8L MITSUBISHI MIRAGE 4G93 SOHC 16V
Now the only ones that I would really be needing out of all this are the Valve Cover gasket, and the Exhaust Manifold gasket, but will all of the other gaskets fit just fine onto our engine? It is on eBay, and it runs about 35 for the set with shipping.
Here is the link: There are many of these up there but here is one i was looking at
Thanks in Advance!
Old Jun 6, 2009 | 11:29 PM
imalancerman's Avatar
Bump for info. I wouldn't think it would work too well since they don't include the 97-02 mirage and thats the car we are mostly compatible with. I would check a mirage forum or ask one of the mirage guys in our forums if the two generations of mirage, the 93-96 and the 97-02 are compatible and you would probably have your answer. Btw, graphite head gaskets suck and I don't think it would fit our car anyways since its manufactured for a 1.8 block and ours is a 2.0 block. Maybe there isnt much difference but still.
Old Jun 6, 2009 | 11:34 PM
sikrsix's Avatar
Why not just buy some "permatex" and apply that. It will hold just as good as a gasket if you prep the area properly.. aka brake clean.
Old Jun 6, 2009 | 11:35 PM
moreryce's Avatar
Graphite headgasket would be a big no no.. especially since the stock one is Metal...
I would suggest just getting the Valve cover gasket itself and just not worry about anything.. i can get you one for $10 for just the valvr cover gasket or for $18 i can get you the spark plug tube seals as well included.. PM me if you want im located in SoCal..
Old Jun 6, 2009 | 11:41 PM
bcollinstex's Avatar
you can order a set from rockauto
you want the cover gasket (1) and spark plug tube seals (4)
here's the part number for a fel-pro set VS50535R and a beck/arnley set 0361549
Old Jun 6, 2009 | 11:43 PM
the sets I listed also fit
MITSUBISHI MIRAGE (1999 - 2002)
MITSUBISHI MIRAGE LS (1997 - 1998)
Old Jun 6, 2009 | 11:49 PM
check out autopartsgiant.com Thats where Im ordering everything from and they are dirt cheap. Free shipping on orders over 50 too and they have all the gaskets and everything for our cars. They even carry CV axles and good luck finding those through our auto parts stores. Trust me Ive looked.
braille
17
Feb 26, 2009 03:49 PM
dcshoeco16
Nov 21, 2008 03:42 PM
MattevoVIII
15
Oct 20, 2008 01:49 PM
Lumpy
20
Dec 18, 2007 02:19 PM
dane_stone
Canadian Forum
Aug 19, 2004 09:19 PM
