Evo swap into 02 lancer?
Old Feb 18, 2011 | 12:19 PM
  #46
OZ_racing's Avatar
Veteran: Air Force
Smile
Originally Posted by imalancerman
Haha, find me a few used evos thatve been taken care of, meaning it has less than 60k on it, and everythings stock, for 15 grand. You speak as though its a common thing. Honestly, the only evo I would ever buy would be one thats completely unmolested. I know those arent 15k. No point in buying a car thats been modded. Two reasons, A. you dont get the joy of modding it yourself, and 2. any person who goes and mods their cars isnt doing it just for fun. I promise you they've hot rodded that chassis. No thanks on that for me. I have fun modding my lancer and getting to learn all about it from the lancer community. Look how far the lancer has come. There is now a dohc swap available without removing the engine. We have a number of swaps we can do also if we really cared. Honestly, the evo swap is a over priced and over rated swap compared to the other ones that are available. I would stick to the g64 and slap an evo head on it if you want the evo engine so bad. Then throw a evo ecu and a custom turbo kit on there. You should still be well under 6500 bucks.
Personally, for those of whom do not have the money for a motor swap G64/G63 more or less at minimum of $2k for Forced Induc.. A DOHC swap would save you a good chunk of change, much more time, and gain atleast 30-40 ponies at the rubber.
Not everyones personal alternative, but i personally am limited on funds so with my tax return just arriving, id rather not yank this block at 133k miles on it and just leave it the way MITSU should have being at that DOHC. Shoulda been a requirement IMO
But i will agree this is YOUR idea and project. If money has no say follow through with your idea. Good luck on the build, I too would love to see this creation of masterpiece ressurect!
Old Mar 22, 2011 | 07:22 PM
  #47
scotty8817's Avatar
Ever make that swap?
Old Mar 22, 2011 | 07:23 PM
  #48
scotty8817's Avatar
ever make the swap?
Old Apr 23, 2011 | 06:57 PM
  #49
OZ_racing's Avatar
Veteran: Air Force
The dohc? or the engine itself?
Old Apr 23, 2011 | 07:06 PM
  #50
EVO KiiD's Avatar
I was told this was a very hard. time consuming and exspensive swap. It might be easier do do an evo 3 swap or just turbo the exsisting platform.
Old Apr 24, 2011 | 04:48 PM
  #51
Jehuty's Avatar
Based on your post of doing an evo 3 you should not be doing any type of swap...
Old Apr 25, 2011 | 12:47 AM
  #52
EVO KiiD's Avatar
What does this mean? It makes no sense to me I'm throwing out a suggestion I don't need a swap nor have I done one I drive a Evo 9 MR DD.
Old Apr 25, 2011 | 06:48 PM
  #53
turbotime's Avatar
It means you clearly have no idea what your talking about so probably a better idea in this situation to just not say anything rather then trying to increase your post count.
The evo 3 engine is backward configuration to the lancer so doing a evo 3 swap would be even more difficult.
Congrats on your evo 9, probably a good idea to stay in the evo section.
Old Apr 26, 2011 | 10:40 AM
  #54
EVO KiiD's Avatar
You're totally right about the evo 3 my mistake I thought I recalled someone on another forum saying something about doing the evo 3 motor in a lancer. Nice lancer, it was a new topic no need to be such a jerk.
Old Apr 26, 2011 | 07:19 PM
  #55
LancerIsGo's Avatar
See the thing is its not a time consuming swap. As I've said before, its pretty straight forward. The engine and transmission drop right in without any type modifiation. Of course the passenger side motor mount will have to be reinforced but thats about it. Also Im not planning on doing AWD, just FWD. It would be nice to do a RWD but I dont have the tools nor the experience to do the fabrication. Yes I know there will be traction problems but I'll figure it out. The Hardest part about the swap is the electrical portion, which still in itself is pretty damn easy too. I really dont understand why people make this out to be such a difficult, time consuming, and sometimes people say impossible swap. How about you naysayers try doing some research before you dog the idea. Unfortunately people are right on one thing, it is an expensive swap, the engines and transmissions start around 2.5K to buy.
On another topic. Its easy to put a DOHC cylinder head onto to the USDM Lancer. The 8th gen (1996-2003) JDM Mitsu Galant used a 4G94 with a DOHC cylinder head. All you need to do is buy that head(with subsequent internals), a larger timing belt, 3mm headgasket(instead of the 5mm that comes with the SOHC head), and the JDM 4g94 idler pullies. And no, you dont need a different intake manifold, the stock one works just fine. There's really no difference here, you dont have to modify anything, both SOHC and DOHC use the exact same bottom end and have the same bore and stroke and deck height. A difference between the 2 is the DOHC runs at a 11:1 compression ratio as opposed to the 9.5:1 on the SOHC. The DOHC head can net you around 25-30 wheel horsepower. The problem is actually finding the parts, there's a guy in Australia who has a stockpile of them but you will pay the price. Just look up LLT Racing, he's got the stuff.
Or you could just take a DOHC head from a 4g93.
Old May 3, 2011 | 02:45 AM
  #56
Jehuty's Avatar
No one said that the evo swap was difficult, but as you stated yourself the issue would primarily be traction. The axles can handle like 300 WHP if I'm not mistake, at least reliably. Not to mention the tires that our car can fit aren't the most "race" worthy. If you just daily drive your lancer, there is really no point...and even if you auto x, still no point because the different engine puts you in a whole new class where you would get your *** handed to you.
EdrickReyes
Feb 21, 2015 08:45 PM
OZ_kidd
Lancer How Tos / Installations
21
Jul 7, 2014 01:50 PM
fawzie13r
Lancer Tranny/Drivetrain Tech
Apr 30, 2012 08:08 PM
SiK MaRiN3
Lancer Engine Management / Tuning Forums
Aug 24, 2011 11:20 PM
Zelenin
Lancer Engine Tech
40
Jul 16, 2011 05:11 AM
