08 Lancer Engine Swap
Old Feb 4, 2010 | 05:12 PM
Zelenin's Avatar
Question 08 Lancer Engine Swap
Would it be too ridiculous of an idea to eventually do an engine swap on this car?
Don't get me wrong, I know it would be crazy expensive, but what if you did it to this when the car is 10 years old? Instead of buying a new car, what if invested money into building a new engine and swapping it in?
I know that a lot of civic owners do engine swaps with h22 / b16 / b18. Is there any particular engine out right now that would be a good match with this econo car?
Its just I'm really looking into buying a different car, maybe some sort swapped accord or used s2k...but I still love my lancer. Could this car ever be feasible nice without 5 million dollars?
Old Feb 4, 2010 | 05:24 PM
Zelenin's Avatar
Never mind, I just read up on it. Its a totally useless idea with a lancer lol.
Old Feb 4, 2010 | 05:47 PM
yitzac1990's Avatar
"4b11t"
Old Feb 4, 2010 | 06:27 PM
Zelenin's Avatar
Originally Posted by yitzac1990
"4b11t"
Well yeah, but its not 4WD...its just too expensive with these new cars and there are way too many computers
Old Feb 4, 2010 | 06:41 PM
tristat3's Avatar
lol
Old Feb 4, 2010 | 09:00 PM
yitzac1990's Avatar
Evo X OEM short block: $1900
as far as we all know, the lancer tranny will bolt right up to the Evo Block, possibly head too. but if you need a head...
OEM Evo X head: $1800
OEM Evo X ECU: forget, but under $1000
so the whole swap cant cost more than $4700 and labor.
supposedly lol
Old Feb 4, 2010 | 10:12 PM
Zelenin's Avatar
supposedly lol
Uh...the lancer tranny can't handle that, need awd conversion, need bunch of custom work, evo ecu won't work. The car will still blow up. Basically need to replace whole car.
= $10k swap = $26k-$27k accident waiting to happen.
Not to diss this car but I can't believe I bought this car, I was too young at the time. I'm going to stop putting money into this pit. At least its paid off...I finish Bio degree in 1 year, I'm just going to use this as my daily driver and buy something nice.
Old Feb 5, 2010 | 05:43 AM
yitzac1990's Avatar
lol why do you NEED the AWD conversion? honestly, you could just be partially ghetto and leave the driveshaft disconnected, and keep the lancer rear setup. you wont need too much custom work, if any at all. why wont the evo ecu work? it plugs right up and you would need a tune ANYWAYS for something like this.
Old May 6, 2011 | 07:35 PM
Ghilversumtuner's Avatar
08 lancer tricked out
Is it possible to replace the drive shaft with an 08 evo x drive shaft?
Old May 6, 2011 | 09:15 PM
villero1834's Avatar
i did a 4b12 swap , engine is way cheaper than a 4b11t and u can use all ur oem parts tranny , etc.. and i dont care what people says , u do feel a big difference, it has a better low end.Im pretty sure(im actually guessing ) that the 4b11t should be a direct swap too
Old May 6, 2011 | 10:21 PM
Lightbulb tuner up my 08 lancer
whats the difference between the two and where can i find a 4b12 engine for sale, and is it possible to change my drive shaft with an evo drive shaft?
Old May 7, 2011 | 08:19 PM
graphiteralli09's Avatar
4B11T:
Engine type Inline 4 cylinder DOHC 16v, Turbo MIVEC
Displacement 2.0 L (1,998 cc)
Bore 86 mm
Stroke 86 mm
Compression ratio 9:1
Fuel system ECI multiple
Peak power 206 kW (280 PS) at 6,500 rpm (Japanese market)
217 kW (291 PS) at 6,500 rpm (US market)
177 kW (240 PS) (Lancer Ralliart)
217 kW (295 PS) at 6,500 rpm (European market)
Peak torque 422 N·m (311 ft·lbf) at 3,500 rpm (Japanese market)
407 N·m (300 ft·lbf) at 4,400 rpm (US market)
343 N·m from 2,500 to 4,725 rpm (353 N·m at 3,000 rpm) (Lancer Ralliart)
366 N·m at 3,500 rpm (European market)
4B12:
Engine type Inline 4 cylinder DOHC 16v, MIVEC
Displacement 2.4 L (2,359 cc)
Bore 88 mm
Stroke 97 mm
Compression ratio 10.5:1
Peak power 125 kW (170 PS) at 6,000 rpm
Peak torque 232 N·m (171 ft·lbf) at 4,100 rpm
Old May 8, 2011 | 11:04 PM
what would the total whp be?
So how much more hp would the oem aftermarkets give if you do engine swap with the 4b12 and add A turbo?
Old May 8, 2011 | 11:40 PM
I found an after market performance racing drive shaft for the 4b11 if I would add the evo x parts to the 4b11 would it work out or would i still have to leave the drive shaft disconnected?
Old May 9, 2011 | 10:38 AM
My installer is telling me that because if my c. Ratio the 4b12 will have a better low end or more tq if u want to call it like that its just harder to tune than a 9:1 or a 10:1 cr ratio (4b11 and 4b11t). But idk for real theres only one 4b12 with turbo that im aware of and it has the rrm kit so my set up is diff ill have an ra kit lets see what happena were are setting the bar a lil higher than rrm
