What are the chances of getting stronger internals for the lancer?
Old Sep 23, 2009 | 09:15 AM
Sicktght311's Avatar
NA mods = higher compression ratio, but we're already at 10.5, so putting anything higher will start getting a little overkill. You'd be better suited tweaking the rest of the system before upgrading the internals. You wont need to beef them up for NA applications since even with MAJOR upgrades you still wont be pushing what a mild turbo kit would.
Putting on the SRT or EVO pistons would benefit turbo applications where you want to turn up the boost, but really at the same time, if you're getting into the amount of power that would require lowering the compression ratio, you might as well get everything done while you're at it. And i just read the following.
compression ratios
4b11t - 9.0 to 1
4b11 - 10 to 1
4b12 - 10.5 to 1
SRT-4 - 8.5 to 1
So the SRT's internals have a pretty low compression ratio for a swap unless you plan on making SERIOUS power, and in my honest opinion, if you're pushing THAT much power, you're probably better off doing a complete custom engine rebuild, which will cost such an ungodly amount of money compared to just doing a 4b11t engine swap.
Old Sep 23, 2009 | 10:40 AM
yitzac1990's Avatar
compression ratios
4b11t - 9.0 to 1
4b11 - 10 to 1
4b12 - 10.5 to 1
SRT-4 - 8.5 to 1
i totally agree man, i want to do 9.0:1 eventually, and the good thing is that our rods are already forged, one less thing to buy!! lol
Old Sep 23, 2009 | 08:15 PM
turbotime's Avatar
Originally Posted by yitzac1990
wow! hey not to bash you or anything, but where did you find your info? I have nothing to say against it, just wondering if this is all true, because I eventually want to get 300 whp
I've been reading through the lancer and caliber srt4 service manuals
you could go with evo internals but they cost around double what the srt4 caliber internals do. The C-SRT4 rods have a longer stroke with still gives you the 2.4 displacement which is why I really like this option over the evo x.
plus the hp range is not far off at all. 285 C-SRT4 to 291 Evo x
From what I've read so far, our heads are pretty well all the same.
I've been browsing the C-SRT4 boards any many guys run 400+ hp on stock internals with no issues. For me that is plenty and I'm not even braking the bank rebuilding my entire engine.
just some food for thought.
Old Sep 24, 2009 | 12:22 AM
JHizzle's Avatar
yep, if you planned on an all motor 200-250whp car..you kinda got the wrong car..
not downing the OP, i'd keep my lancer as a daily if i could get 200whp all motor out of it without having to spend the amount that a turbo costs.
Old Sep 24, 2009 | 07:09 AM
yitzac1990's Avatar
i actually found some, I think, Evo X OEM pistons for REALLY cheap, but I forget where I found them....also, im 2008 GTS so I have 2.0, not 2.4....evo internals will work great for me lol
LVSBB6
19
Apr 16, 2023 11:56 AM
Turbotech
Lancer Aftermarket Forced Induction Tech
40
May 26, 2014 01:39 PM
maximusnz
Nov 26, 2013 08:35 PM
Cusco USA
Jan 12, 2012 07:52 PM
jack syn
Dec 1, 2006 04:16 AM
