srt4 internals in a 2009 lancer gts
Old Oct 14, 2009 | 09:28 PM
09lancerGTS's Avatar
hello all, i was just wondering if i could get more info on srt 4 piston and rods. i have seen in at least two threads on here someone saying that the srt 4 pistons and rods are compatible with the 4b12.
my question is, are there any modifications needed for this or can u just get the srt pistons and rods and include them in a regular rebuild with new bearings gasket set...ect
i am planning on going turbo next year and when i do so i would like to rebuild the engine stronger for peace of mind.
i only plan on running 12-13 psi of boost.
any info would make my day
thanks Brock
Old Oct 14, 2009 | 10:03 PM
ShadowES's Avatar
good luck with that. id bet you could seeing how the 2.4 mits and the 2.4 dodge/chrysler are the same block from the diamond star global world engine.
Old Oct 14, 2009 | 10:13 PM
the bore and stroke is the same on both engines right?
Old Oct 15, 2009 | 03:16 AM
BABYGOTBACK's Avatar
That SRT-4 is a monster. A total sleeper. People pull up to a light with my buddies, and laugh at his stripped neon; light turns green and by the next light they are asking, " you got a HEMI in that!?"
Old Oct 16, 2009 | 06:06 PM
does any one know about the srt 4 internals for the 4b12 ? ? are there any mods needed for them or what??
Old Oct 20, 2009 | 12:39 PM
reismj's Avatar
The Neon SRT-4 does not have the same bore / stroke (b = 87.5, s = 101mm). The only srt-4 package that would fit would be from the caliber.
And since, as stated by ShadowES, both the 4B12 and the SRT-4 engine are made from the same block (GEMA), I don't think you'd need any special parts or work to get the SRT-4's rods and pistons in.
Old Oct 22, 2009 | 07:50 PM
okay thank you reismj for your help. you dont know of any after market head gaskets for this engine as well? I have searched and come up with nothing
Old Oct 23, 2009 | 11:12 PM
ShadowES's Avatar
if no one can tell your buddy's car has a rough lope and sounds mean why race it, ther are just some things you dont go after......
but either way. the best way to find out is to do some research on the SRT4 engine bore stroke and find out what the mitsu bore and stroke is. you never know they may be closer then you think.
Old Oct 27, 2009 | 10:30 AM
ShadowES's Avatar
NEON SRT4
• Turbo compressor
• 2,429 cc 2.4 liters in-line 4 front engine with 87.5 mm bore, 101 mm stroke, 8.1 compression ratio, double overhead cam and four valves per cylinder EDV
• Premium unleaded fuel 91
• Fuel economy EPA highway (mpg): 30 and EPA city (mpg): 22
• Multi-point injection fuel system
• 12.5 gallon main premium unleaded fuel tank
• Power: 160 kW , 215 HP SAE @ 5,400 rpm; 245 ft lb , 332 Nm @ 2,000 rpm
if you did get the pistons to work without a turbo you would lose power from the lower compression.
Old Oct 27, 2009 | 10:32 AM
ShadowES's Avatar
CALIBER R/T
• 2,360 cc 2.4 liters in-line 4 front engine with 88 mm bore, 97 mm stroke, 10.5 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder ED3
• Unleaded fuel 87
• Fuel economy EPA highway (mpg): 26 and EPA city (mpg): 23
• 13.5 gallon main unleaded fuel tank
• Power: 128 kW , 172 HP SAE @ 6,000 rpm; 165 ft lb , 223 Nm @ 4,400 rpm
Old Oct 27, 2009 | 10:36 AM
ShadowES's Avatar
SRT4 CALIBER
• Turbo compressor
• 2,360 cc 2.4 liters in-line 4 front engine with 88.0 mm bore, 97.0 mm stroke, 8.6 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
• Unleaded fuel 87
• 13.6 gallon main unleaded fuel tank 11.3
• Power: 213 kW , 285 HP SAE @ 6,400 rpm; 265 ft lb , 359 Nm @ 2,000 rpm
Old Oct 27, 2009 | 10:39 AM
ShadowES's Avatar
2006 RalliArt
• 2,378 cc 2.4 liters in-line 4 front engine with 87 mm bore, 100 mm stroke, 9.5 compression ratio, overhead cam, variable valve timing/camshaft and four valves per cylinder 4G69
• Unleaded fuel 87
• Fuel economy EPA highway (mpg): 29 and EPA city (mpg): 22
• 13.2 gallon main unleaded fuel tank
• Power: 121 kW , 162 HP SAE @ 5,750 rpm; 162 ft lb , 220 Nm @ 4,000 rpm
EdrickReyes
Feb 21, 2015 08:45 PM
Srt4...
Sep 28, 2014 06:00 PM
teribble
Aug 2, 2011 10:15 PM
Redline SRT4 v2
17
Jan 14, 2009 06:56 PM
Spinsall4
Aug 31, 2007 07:46 AM
