New engine wont start!!
Old Nov 9, 2009 | 03:03 PM
NOTORIOUSLANCER's Avatar
My old engine cracked from the bottom and lost all the oil. So i bought another 4g94, but after conecting everything the car wont start. The car seems like it wants to turn on but it wont. Seems like theres no spark, but the cam shaft sensor been replaced. The only thing we can think is that the ECU aint working. Any one have any other ideas????
Old Nov 9, 2009 | 03:15 PM
ThunderOZ's Avatar
I know it sounds stupid but did you double check that everything is hooked back up right? Like the coilpacks and everything?
Old Nov 9, 2009 | 03:27 PM
yea i did. We done it like 5 times. We disconected everything and then connect everything back. But also one weird thing is when i connect a neon tube wires to the (-) of the battery and to a bolt where the strutbar is tied down, the light will turn on. But it shounlt be turning on when both conections are grounds????
Old Nov 9, 2009 | 08:04 PM
*02Lancer*'s Avatar
So is the engine cranking and just not starting or not cranking at all? when i bought my replacement motor for my lancer it had been setting for a couple of months and i had to put my injectors from my engine the one i blew up in then it start just fine into the other one because dust got up in there and clogged them. might want to try that. have you tried puttign the gas pedal to the floor while starting?
Old Nov 9, 2009 | 09:42 PM
yea the engine doe crank. And yea i also replaced the injectors with the original ones. Cuz they where clogged and no gas was goin trough. But after doin that it still dont wanna turn on. Putting the gas pedal all the way dint work.
Also something i forgot to mention was that the car did start up for a day, but it would run real slow.
Old Nov 10, 2009 | 03:14 AM
Jehuty's Avatar
CEL came on while it turned? Or was it not on long enough for the computer to register any issues?
Old Nov 10, 2009 | 09:17 AM
Cel dint turn on, but it did after i run it a second time. But it could of been cuz of the headers.... When running i should of takin it to autozone to check what code it was throwing.
Old Nov 10, 2009 | 12:09 PM
blaze_125's Avatar
Check your grounds!
A neon is the worst check light ever. Connect a real bulb if you want to make a check light.
I have a neon hooked in my computer case.
I cut off 1 wire and the thing still lights up. It's dimmer, but it still f kin lights up with only 1 wire hooked up!
Get my point?
Old Nov 10, 2009 | 12:33 PM
Also used a taillight bulb With the harness to make sure and it would still turn on.
Old Nov 11, 2009 | 09:54 PM
any more suggestions??
Old Nov 12, 2009 | 11:32 AM
*02Lancer*'s Avatar
You only need 3 things to make an engine run. fuel Compression spark. So you have changed the injectors i would check the fuel pressure Then i would go to spark i would take a plug off and make sure you are getting spark. That is a good place to start if nothing still a compression test/leak down test, to Check the compression. Hope that helps post the results and we will see what we can do for yah.
Old Nov 12, 2009 | 01:46 PM
Did that today and there is no spark.... Then checkin the block thing that's on top of the spark plugs. The coil pack I think. That conection that it has. And on all three conectors it has charge. But should just the middle one have charge when turnin the key??
Old Nov 14, 2009 | 02:31 PM
*02Lancer*'s Avatar
I dont know monday i can try and look it up on alldata for you if nobody else does before hand.
Old Nov 14, 2009 | 04:31 PM
yea ill apreciate that alot bro.
Old Nov 16, 2009 | 12:20 PM
Would it be posible that the ecu would need to be reprogram??? If so would any mechanic shop or the mitsu dealership be able to reprogram it with out having to take the lancer??
