2003 lancer es timing belt
Old Nov 25, 2009 | 10:58 AM
symX's Avatar
I recently hit 100k miles, and I am not going to go pay 700 dollars for a timing belt/water pump change. I've been looking around online for timing belt kits, and I dont know which one is worth buying. Can anyone tell me what kind of kits they bought when they changed their timing belts/water pumps? Thank you.
Old Nov 25, 2009 | 11:30 AM
nestoledo's Avatar
gates T201RB
Old Nov 25, 2009 | 01:59 PM
symX's Avatar
What else would I need? (gaskets, seals, pulleys etc.) I'm looking for some sort of kit with everything included.
Old Dec 10, 2009 | 05:10 PM
symX's Avatar
Hello, I recently found a kit online, but I'm not sure if its any good.. I'm a car noob, so maybe you guys can give me your opinion. http://www.timingbeltkit.com/servlet...ng-belt/Detail Thanks.
Old Dec 10, 2009 | 05:25 PM
03lances's Avatar
Originally Posted by nestoledo
gates T201RB
+1^^ All you will need is timing belt, water pump, and maybe the water pump gasket if its not included with your pump. Also the knowledge, make sure you know what your doing. Its a straight forward and easy job but you will be crying if your off on your marks when you fire it up.
Old Dec 10, 2009 | 09:08 PM
symX's Avatar
What is a good brand of aftermarket parts for our cars?
Old Dec 10, 2009 | 09:24 PM
03lances's Avatar
Already been posted man go with gates
Old Dec 11, 2009 | 12:14 AM
symX's Avatar
What about the water pump/seals or tensioners/pulleys? is there a kit i can find some where?
Old Dec 11, 2009 | 01:33 PM
03lances's Avatar
If your just changing the belt for maintenence and nothing else (abnormal noise etc.) pulleys or tensioners will not need changed just the belt and water pump
Old Dec 11, 2009 | 01:36 PM
03lances's Avatar
look here
Here
this is the kit you would need if you want to change the pulleys too just would still need the belt
Old Dec 11, 2009 | 03:07 PM
JRR's Avatar
JRR
no offense to orieley since i work at a different auto parts store but you gotta watch them, they gave me a ford v6 valve cover gasket for my mitsu
last i checked we had differnt engines...
josh
Old Dec 12, 2009 | 10:04 AM
03lances's Avatar
josh
I do have to admit the particular store I go to they hired some bright ones the last six months . They used to have knowledgeable people in there but now there so bad I am about to switch companies. The only thing keeping me there is 95% of the time they are cheaper for the same part than the other part stores I have access to. If it keeps up though I will not tolerate it even if it means paying more for the same thing
Old Dec 28, 2009 | 03:00 PM
darkmitsu's Avatar
there is no reason to do a timing belt in your car , a motor can be had for real cheap out of a importer or a junk yard... Ride it till it dies... My timing belt stipped teeth at 110k and I just swapped the motor out for one out of an 06 with 10k miles on it...
Old Jan 5, 2010 | 04:09 PM
Demon_ni2's Avatar
LOL>... not the ideal way to do it.. but yes he is correct.. LOL all my motors have cost me under 300$.. and ive swapped them all myself.
ride it till it dies!
but nah seriously.. just get a timeing belt kit from your local parts dealer, if u dont know what your doing seriously, dont attempt it. I didnt know how to do a timing belt untill on a few weeks ago and ive swapped my motor 3 times this year! and some of it is still voodoo to me. getting all the parts off is a hassel inside the car. lol.. mine actually cost me 550 at the dealer to have changed. and i did it at 60k miles on the dot.
EvO-LOui
Feb 18, 2015 10:38 AM
awdordie
Sep 8, 2014 02:02 PM
evoboy2012
Mar 2, 2012 09:15 PM
AboodsEvo
Nov 19, 2010 06:21 PM
evane
22
May 16, 2010 05:20 AM
