Substitute for Nitro
Old Nov 6, 2003 | 06:06 AM
SE7EN's Avatar
on the intercooler should on paper cool it quicker than regular air
Originally posted by pickleknock
are we talking about spraying ON the intercooler or INTO the intercooler? spraying on will do nothing that regular air wont. spraying into wont do anything unless you add more fuel. pure oxygen will not run cooler by any means... it is used for welding.
Old Nov 6, 2003 | 03:45 PM
pickleknock's Avatar
it may slightly, but water evaporating from the surface of the intercooler would provide MUCH better heat dissapation then o2 flowing over it. the o2 may only be providing cooler temps because of the fact its coming out of a tank, thus its being decompressed which cools it to temperatures lower then the outside air.
Old Nov 9, 2003 | 09:40 PM
SE7EN's Avatar
Celica Re-Birth Projeck, supercharger
any idead on a good supercharger on the celica?
Old Nov 9, 2003 | 09:48 PM
03RallyLancer's Avatar
o my bad thought we were talking about spraying into engine not on intercooler... o2 vs n2o vs co2 would not notice much of a difference
Old Nov 9, 2003 | 09:57 PM
SE7EN's Avatar
we were talking both?
yes...all in information, the more info i get the more smart i will become, so whats ur expertise on spraying to the engine? know anythang of spraying to the cooler?
Old Nov 9, 2003 | 10:03 PM
eldanoloco's Avatar
squirting pure oxygen into the motor could be very very dangerous. oxygen is explosive, i would not want to be driving around with a tank of that in my car ever. oxygen is even more explosive then hydrogen and nitrous. dont believe me? take a balloon full of pure o2 and hold a match to it and since its an oxidizer, it would rapidly accelerate the burning of anything else that was on fire. the oxygen would probably ignite in your intake if there was any type of open flame coming back out of the motor into the intake. very very bad idea.
NO oxygen is not flammable, to be flammable is must be fuel. Here some reading for you:
http://www.madsci.org/posts/archives...6773.Ch.r.html
Its supports combustion, it does not cause it.
Old Nov 9, 2003 | 10:10 PM
eldanoloco's Avatar
And they carry a lot of it in ambulances. Oxygen makes a environment more capable of combustion, O2 in welding is used along with something called Acetylene, the fuel. In an
Oxy-acetylene torch, acetylene makes the flame, O2 makes it hotter.
Old Nov 9, 2003 | 10:16 PM
eldanoloco's Avatar
Re: Celica Re-Birth Projeck, supercharger
Blitz makes a supercharger for the celica GTS, and blitz has a very good reputation with forced induction systems. But if you want to put a lot of boost through it better think about lowering that 11.5:1 compression ratio,
