kamikaze headers question
Old Dec 3, 2003 | 07:49 AM
airlinevomitbag's Avatar
Originally posted by IILANCERII02
i have the header and downpipe, havent installed it yet but looks really nice ... and even if it does rub against something u can easily fix it.
No not any easy fix unless you have a mandrel bender, when you get it on your car you will see why it is not easy. I imagine you could flatten the spot it hits or wrap it a little but still a major pain, it hits enough to most likely wear out and need to be constatly fooled with. I took a picture a while back and put it in a thread to show everone the clearance issue with the DP just search Im too lazy. Only bangs on startup reverse and hard turns gee that isnt much and I have solid engine mounts which severely limits the drivetrain from moving which is the cause of the banging, Id hate to hear it with stock.
Old Dec 16, 2003 | 07:47 PM
LancerOfOZ's Avatar
Installed header and downpipe
I got the header and down pipe on this weekend, along with a new muffler and custom catback. I hear no rubbing clanging or anything everything fit GREAT. It took about and hour and a half. As for the initial thread question, i would say no the header would not fit the stock Down, since the kamikaze header /downpipe combo fit together with 3 nuts and bolts, the stock only has 2. for about 5hrs I only had the header and an intake on and i still saw great improvement and even better sound, but would highly recomend that if you add the kamikaze/RPW/RRM header just spend the extra $150-250 and get a complete header back exhaust put on. I def felt an even better difference between having header w/ stock exhaust and having header with custom. any more questions PM me rock on deffintly worth the money for the this upgrade.
MLancer1986
Lancer Engine Tech
14
Aug 16, 2006 02:12 PM
Walkingchaos
Lancer Engine Tech
Nov 26, 2005 06:17 PM
rayabedi
Lancer Engine Tech
228
Jul 7, 2004 02:32 PM
yellowlancer02
Jan 28, 2003 11:24 PM
yaheardbish
Lancer Engine Tech
May 31, 2002 05:29 AM
