Radiator Question
Old May 8, 2010 | 07:32 PM
Midnightkid's Avatar
Radiator Question
Don't have the time to search thoroughly for the answer, but will the OBX Radiator hoses for the Lancer fit with the Aftermarket EVO Radiators or am I still gonna have to get EVO hoses and just cut em to fit?
Old May 9, 2010 | 08:12 AM
senate6268's Avatar
The necks on the Evo radiator are positioned the same as the Lancer radiator. You will still use Lancer radiator hoses with either radiator.
Old Jun 8, 2010 | 08:26 AM
The radiator install went through without a hitch, but I Couldn't install my oem fan, it was too big and the bolt pattern didn't match. With that said, will an aftermarket fan for an EVO plug into the oem harness of a lancer?
Old Jun 8, 2010 | 11:30 AM
senate6268's Avatar
You should look into picking up some slim fans to install. They can be wired in using the stock Lancer fan harness. Aftermarket fan assemblies for the Evo should work as well, but may require some custom wiring if they don't have the harness connectors.
Old Jun 8, 2010 | 01:06 PM
eusgen's Avatar
Any suggestions where to get some slim aftermarket fans for cheap? where did you get the lancer radiator hoses from? Im looking for red
Old Jun 8, 2010 | 08:53 PM
Any particular manufacturer or model I should look into?
Also, I got the OBX radiator hose. You can find them online just about anywhere. I got mine off amazon lol XP
Old Jun 9, 2010 | 11:52 AM
eusgen's Avatar
Thanks, the OBX hose looks good . Pretty cheap mod for the improved look
Old Jun 11, 2010 | 07:06 PM
jwick76's Avatar
N/M, answered my own question...inside diameter of 32mm, outside of 38mm. So I went with a 34mm gauge sending unit adapter. eBay JDM special.
Last edited by jwick76; Jun 12, 2010 at 06:08 PM. Reason: answered my own question
