engines
Old May 28, 2010 | 09:53 PM
ambystom01's Avatar
The Ralliart is a 2.4 L motor, I think it's DOHC but I'm not 100%. Yes people have put it in a Lancer that did not come with it. Diavlo did it and said it wasn't worth it if you have the 2.0 L 4G94.
Old May 28, 2010 | 10:46 PM
JRR's Avatar
JRR
also isnt the ra a mivec? if it is then different ecus then as well i assume.
Old May 28, 2010 | 11:34 PM
subbie racer's Avatar
swapping out motors and ecus wouldnt be much of a problem and 2.4L 162 hp sounds alot better then a 2.0 120hp, last 2 days i made my exhaust abit custom by cutting out the muffler and resonator i think it was but kinda looked like a small muffler, put a straight pipe and welded it, i felt a major improvement, i do still plan on an ebay exhaust system with headers, just had nothing else to do but it sounds nice, not loud or ricey
Old May 29, 2010 | 11:57 AM
would the 2.4 bolt right in? cause theres one by me with only 15k asking $1000
Old May 29, 2010 | 12:31 PM
ambystom01's Avatar
No it won't bolt right in, you'll need to get more parts than just the engine.
Old May 29, 2010 | 12:56 PM
is the mivec the same as the 2.4 eclipse motors?
Old May 29, 2010 | 03:35 PM
slatermvp's Avatar
i don't think it is. Different engine codes, the ralliart is the 4g69 and the eclipse is the 4g64 if I'm not mistaken.
Old May 29, 2010 | 04:36 PM
ah im just wondering what else is needed with the 4g69 to install it, other then the ecu, i tried to google it but nothing
Old Jul 13, 2010 | 09:26 AM
Jogenmaru's Avatar
It's SOHC Mivec. The swap is not worth it as it gets you the same power as the 4G64 swap and cost a lot less. As stated earlier their are 4G94 Lancer's out there with a 4G93 Dohc conversion that also cost less and are close to the 4G64 swap. I think there are only 2 completed swaps in the USA for a DOHC 4G94.
This is from a boosted 4G94.
https://www.evolutionm.net/forums/la...4-boostin.html
Mikeshkap13786
Mar 1, 2017 08:46 PM
neilm
Dec 18, 2012 09:35 PM
Benji Van Eerte
Nov 26, 2012 05:13 AM
Benji Van Eerte
Nov 24, 2012 01:17 PM
oneofakindracer
Apr 9, 2009 04:37 PM
