Piston Bore Size? 4G94
Old Jul 14, 2010 | 08:18 PM
Punz203's Avatar
Question Piston Bore Size? 4G94
ALot of aftermarket parts for Honda/acuras with 81.5mm bore pistons. How important is bore stroke and will higher/lower bore stroke gain/lose HP/TQ or even fit. Would be nice to think outside the box.
Old Jul 14, 2010 | 09:10 PM
senate6268's Avatar
The pistons will technically fit in the cylinders. 81.5mm is 81.5mm. But you now need to look at wrist pin size/location, piston height, piston to valve clearance, rod movement clearance if installed on piston, etc. There are alot more factors to consider than bore.
Old Jul 14, 2010 | 10:37 PM
Punz203's Avatar
Yea your right.... just need to try it... Honda/Acura pistons are cheaper then lancers.
Old Jul 16, 2010 | 10:09 PM
llt-racing's Avatar
I have use honda B-series pistons in a 4G94 you need to modify the small end and bore it out a few thou. Then you will need to shave the piston skirt so it will not make contact with the crankshaft.
But then you get positive deck height around .5-.8mm cant remember its probably less, need to get a head gasket to suit.
R/TErnie
80
Jan 7, 2021 02:46 PM
maxroach
Jun 15, 2017 02:50 PM
trinydex
35
Sep 6, 2015 08:11 AM
Perk77
Aug 28, 2008 07:59 PM
redlinedrift
44
Jul 14, 2008 01:53 PM
