Block: 4g63 Gst Eclipse vs 4g63T Evo 8
Old Jun 13, 2017 | 11:05 PM
maxroach's Avatar
Are they same?
I mean, bore, stroke, oil and coolant holes, etc?
Thank
Old Jun 14, 2017 | 09:34 AM
bboypuertoroc's Avatar
Veteran: Army
Bore and stroke are the same, but none of the rest matters because the engines are reversed.
Old Jun 14, 2017 | 10:30 AM
barneyb's Avatar
When you've worked on both you find yourself saying, "The balance shaft in the front - no wait a minute is that in the front or the back?"
Old Jun 14, 2017 | 10:36 AM
Veteran: Army
For a short time when I first bought my Evo I still had my '96 GS-T. That was "fun" going back and forth between opposite 4G63 engines lol.
Old Jun 14, 2017 | 07:05 PM
barneyb's Avatar
This is a comparison of the 6 bolt DSM engine to the Evo 8 engine - the only two engines I am familiar with.
Timing belt - same on both
Accessory belt - as I recall the DSM had three belts - always out of tension and noisy - the power steering belt would squeal every time the engine was started. On the Evo engine - solved.
Exhaust manifold studs on the DSM engine had a habit of snapping due to expansion and contraction of the manifold. Evo engine - solved.
Spark plug wires were short lived on the DSM engine. Evo engine - they last a long time. Nobody seems to recommend aftermarket plug wires.
Lots of people spun out the balance shaft bearings in DSM engines with good oil pressure. Occasionally has occurred in the Evo engine but close to solved.
The DSM knock sensor heard everything and would pull timing on a noisy engine until it would barely run. The Evo engine knock sensor is much more selective about what it listens too. Sometimes it seems to ignore everything. DSM engine wins here.
Throttle plate would get sticky in the DSM engine. Evo engine does the same thing.
Valve guides were good for about 100K in the DSM engine. Supposedly solved in the Evo engine.
Rubber in the DSM crank pulley would part dumping the accessory belts and maybe taking out the timing belt. I've never heard of an Evo crank pulley doing this but that rubber is getting old.
Overheat a DSM engine once and warp the head. The Evo engine seems more resistant and has a better cooling system.
A DSM valve cover gasket would start leaking at 15K. Tighten the capscrews and get another 15K before replacement. An Evo valve cover gasket, if left untouched, doesn't leak.
Old Jun 15, 2017 | 08:12 AM
Chrispy0530's Avatar
Awesome info ^
Having both platforms, good to know this info.
Old Jun 15, 2017 | 02:50 PM
barneyb's Avatar
Originally Posted by Chrispy0530
Awesome info ^
The comparisons are of OEM parts and OEM design separated by 11 years. I think it is an amazing difference.
PHILLY EVO
Apr 8, 2012 03:45 PM
djikonatx
Jan 12, 2012 10:56 PM
crazy cunuc
10
Dec 22, 2010 08:51 AM
Cow
Jul 30, 2007 06:02 PM
scottsee
Mar 27, 2005 07:42 AM
