o2 sensor fuctions
Old Nov 20, 2003 | 04:16 PM
pickleknock's Avatar
o2 sensor fuctions
does anyone know what each of the two o2 sensors do? does the first one or the second one pull a/f readings? i have an exhaust leak before my second o2 and i am wondering if that could be screwing up my a/f ratios.
Old Nov 21, 2003 | 06:06 AM
laxwax's Avatar
From what I've been reading, I'm 99% sure it works like this:
1st O2: before the 1st cat, takes the A/F readings
2nd O2: before 2nd cat, compares reading with 1st O2 to make sure 1st Cat is working properly
Thats why when you install a header and remove the first cat, your A/F is fine and your CEL comes on. When 1st O2 reading and the 2nd O2 reading are the same, it makes the computer think your 1st Cat isn't working (well, it's not, cause its not there and sitting in your garage). If you add a Mil eliminator to the 2nd O2, you change the voltage output to the computer and "trick" it into think the 1st cat is working properly.
So if your leak is after the 1st O2, it shouldn't mess you A/F.
Old Nov 22, 2003 | 07:34 AM
IILANCERII02's Avatar
laxwax pretty much wrapped it up in a nut shell!
Old Nov 22, 2003 | 07:58 AM
MalibuJack's Avatar
Is anyone aware of someone who sells just the O2 simulator (not a Cat delete and eliminator kit)??
Old Nov 27, 2003 | 03:24 AM
JVlancer's Avatar
get a wideband o2 sensor.. the only way to tru tune your a/f rations.. i need to get mine this week.. u can get them off ebay for around 300 bucks
malac0da13
Dec 5, 2010 05:53 AM
SiC
12
Aug 21, 2008 04:21 AM
Racer24x
Lancer Engine Tech
Jul 26, 2007 03:08 PM
TomsEVO
AEM EMS
Jun 22, 2006 05:44 PM
WishIhadaEvo
Jul 3, 2005 10:25 AM
