Cams and such for 2.0/2.4 NA?
I know the question has probably floated around a couple of times, but for those of us that dont want a lot of power from a turbo, does anyone know of any companies that make Cams for the lancers? or where we can even get some customly made? ideally for 2.0
i just want to get around 190-200whp at the most. nothing crazy. i would even be happy with 180whp.
They didnt say anything, but that all depends on the lift and duration of the cams. What they should do is increase the power as well as provide a wider power curve, so that its available earlier. I just hope it pretty long duration and lift and they come with new valve springs. If such is the case, then u can expect close to civic si power.
Anyway. definitely need reflash with new Camshaft.
If they are concerned, they should only increase the MIVEC part of the lift, so idle should be ok... I assume.
i bought this car because i drive a decent distance to work, the tops either of those cars get on the freeway will be the 20, and thats on a good day. i started to get a civic at first, but i wanted something more flashy without spending 30k. got the lancer and i guess i expected too much from the car as far as power wise. i dont want to sell it because its a beautiful car but i need something with at least a little more pep which is why im considering the genesis coupe
you do know that evo x and ralliart cams have way differnt compression and are made for turbo, get those cams and you will lose a lot of power instead of gaining
i thought that was common sense for someone to make a statement like that like they've actually done research over it. if you know the cams would fit you should know that it wont really work with n/a lancers.
anyway if the price is right this should be the best mod to come to these cars.
