De with evo x cams
Old Feb 22, 2011 | 07:04 AM
mrbloink's Avatar
De with evo x cams
Hi I just found a set of evo x cams for $150 a pair. will these be a direct bolt on in the DE? I am wondering because I realize that these cams are for a turbo car and the DE is NA. Will this cause problems?
Old Feb 22, 2011 | 07:48 AM
lancer0220's Avatar
https://www.evolutionm.net/forums/la...vo-x-cams.html
should be drop in according to the comments in that thread.
Old Feb 22, 2011 | 10:43 AM
Panis's Avatar
The cams are a direct fit, however you will need to re-tune your ecu.
Old Feb 23, 2011 | 08:18 PM
Lost Viking's Avatar
Cams without the tune will probably do more harm than good. Also, you will need new valve springs to handle the higher lift of the Evo cams. Check out that link for more info.
Old Feb 24, 2011 | 07:19 AM
mrbloink's Avatar
what is the stock compression ration vs the new one with the stage 2 cams? does anyone make flat faced valves for the evo?
Old Feb 24, 2011 | 09:59 AM
Cams have nothing to do with compression ratio.
Old Feb 24, 2011 | 12:23 PM
M@verik's Avatar
Compression ratio is changed when u change the pistons, or the headgasket or the stroke.
Old Feb 24, 2011 | 03:37 PM
view's Avatar
Do you know which is specs the cams stock the lancer DE and ES ?
Old Feb 26, 2011 | 10:56 AM
mrbloink's Avatar
Sorry I'd meant to ask about the lift duration. I wanted to make surte the clearences were ok. I was also wondering if there are higher compression pistons or flat faced valves
Old Feb 26, 2011 | 10:20 PM
M@verik's Avatar
Lift and duration are different things
Also u will need new retainers and springs.
As for the other 2, not sure yet. Perhaps u can get it from another engine.
Fedris
Lancer Tranny/Drivetrain Tech
Aug 29, 2016 09:49 AM
Hugh Big Dummy
Jan 29, 2016 08:22 AM
Prosly
Apr 20, 2015 12:58 PM
wickedboost
Jan 29, 2012 08:28 PM
silvrevo
Mar 20, 2003 12:06 PM
