ECU damaged
Old Mar 23, 2011 | 04:54 AM
taaj's Avatar
ECU damaged
I am looking for a used ECU for my 4B11 Lancer GT, the ECU simply is not recovering is not availabel at the service center. I am ready for immediate purchase.
Old Mar 23, 2011 | 05:12 AM
taaj's Avatar
does anyone has any idea how to recover the ECU, our dealer service center said its completely wasted
Old Mar 23, 2011 | 08:54 AM
CamShaft's Avatar
What happened to it, or did it just fail? If the Engine ECU is no good, then you have to get a new one! Try looking in wreckers for one and see if mitsu can reprogram it for you.
Old Mar 23, 2011 | 11:00 PM
taaj's Avatar
we were writting a reflashed file to the ECU and it stalked half way, an error message displayed and we couldnt recover the ECU, although fans work when ignition is on.
Old Mar 23, 2011 | 11:30 PM
02-Lancer-Es's Avatar
Auto or manual ?
I might have one for you boss .
Old Mar 23, 2011 | 11:41 PM
Nvm just noticed it was for a 08+
Old Mar 31, 2011 | 02:18 PM
dadsgts's Avatar
lmfao your ecu is not wasted. Its stuck in program mode. Seriously i have done this i dont 5-6 times trying to flash a ra map. Easy solution and takes a whole 20 mines of your time.
http://www.***************/forums/sh...ad.php?t=29820
wanted to mention before you try to do this try the easiest thing first. With your key in ignition turn it towards the start position without your foot on the clutch. This should stop the fans from running you may be able to flash it at this point. try to flash the ecu if this doesnt work then you need to use the bench monthod. You may have an issue from here forward with the fans running when the ignition is on. Not a big deal however you can flash when the fans are on so again without starting the car turn the key as to start it. No clutch just turn the key. if its a auto put it in drive and turn the key should stop the fans from running!!!!!!!!!!
eclipzed
Dec 22, 2008 02:59 PM
Slow Evo
Mar 18, 2007 03:45 PM
Evolved Monkey
Mar 29, 2006 02:43 PM
Aussie CG
Lancer Aftermarket Forced Induction Tech
Aug 6, 2005 09:06 AM
joseph k
Lancer Engine Tech
Dec 11, 2004 11:45 PM
