Help with whining noise??
Old Jun 13, 2011, 11:59 PM
jrsimon27's Avatar
Hi guys ive had this annoying problem with my lancer gts the thing is that every time i start to run my car really hard after a couple minutes you can hear a whining noise coming from the engine compartment if i rev the car to 6000rpm in 3erd gear oh by the way its a cvt and let the revs come down slowly i can hear the whining noise i took the car to the dealer they told me the noise came from the engine damper so guess what? They made me buy a new one then went to test drive it and the noise is still there, i asked the tech if it could be the cvt that i may need an oil change and he told me no cause you change it at 60,000 miles and that it cant be the gearbox cause when you put the car in neutral an accelerate you can still hear this whining noise so what do you guys think it could be?? Thanks for the help!
Old Jun 14, 2011, 12:04 AM
jrsimon27's Avatar
When driving normal there is no whining noise forgot to tell this
Old Jun 14, 2011, 11:49 AM
LiX
LiX's Avatar
If I understood correctly, the noise appears only when you rev above 6000 rpm, no matter if the car is at neutral or driving?
Old Jun 14, 2011, 12:30 PM
jrsimon27's Avatar
Well not exactly it starts to make this whining noise when i start to drive in a spirited form its when i push the car hard after a while it starts to whine it does it while in neutral or drive.
Old Jun 17, 2011, 10:13 AM
quickflips's Avatar
it may be your air filter. check to make sure it is snug and in place.
Old Jun 17, 2011, 10:57 AM
Iowa999's Avatar
Originally Posted by jrsimon27
Hi guys ive had this annoying problem with my lancer gts the thing is that every time i start to run my car really hard after a couple minutes you can hear a whining noise coming from the engine compartment....
First off, I think that it's extremely uncool for you to force your girlfriend to ride in the engine compartment, regardless of how she reacts to your "spirited" driving.
Second, I'd go a half-quart over full with the oil and see what that does. Maybe, since she's right there, your girlfriend could put the extra oil in for you. Note that you might have to tell her to put it in via the "710" cap. Depending on how you wedged her in there, her perspective could be reversed.
Old Jun 19, 2011, 12:13 PM
jrsimon27's Avatar
I checked the airfilter and its fine!
Old Jun 22, 2011, 08:51 AM
YeOldeLancer's Avatar
Check the belt. Make sure there's nothing obstructing it, wedged in it. Also, it should be covered under warranty so you shouldn't have to pay for a new damper.
Have the dealer diagnose it properly as it should be a warranty issue.
I would advise against overfilling your engine with oil.
Old Jun 23, 2011, 04:59 AM
jrsimon27's Avatar
Update: i changed the cvt oil and whola no more whining noise i drive the car hard and everthing is back to normal iam so happy!! Thanks guys for the help!
Old Jun 23, 2011, 02:08 PM
phayder808's Avatar
seriously? thats all you had to do?... .....welp there goes another paycheck
Old Jul 5, 2011, 03:39 PM
Belgaram's Avatar
Is my wife in your trunk?
Old Jun 16, 2015, 07:51 AM
BASOOL's Avatar
Lool that joke made my day xD
Old Mar 3, 2016, 03:30 PM
J2K10LANCER's Avatar
i keep getting the whiny noise with my transmission too? i wonder what i could do to help fix it.
Old Mar 18, 2016, 07:55 AM
FF_Nyck_66's Avatar
Change your CVT fluid. I had the same problem. It was resolved after the fluid was changed!
Old Mar 19, 2016, 02:12 PM
how do you change it do you have a guide that tells you where the drain plugs is....also where to fill it.
Quick Reply: Help with whining noise??
