02 lancer oz wont fire
Old Sep 26, 2011 | 07:44 AM
D3rr's Avatar
Hey I think this is the right forum for this. I have a 02 Lancer oz and I was driving down the road an it quit on me. Its turnin over, I can smell gas, but no fire. I changed the crank sensor, and the ecu with ones off of my parts car(that ran) and still nothing.
Old Sep 26, 2011 | 10:32 PM
03lances's Avatar
Sounds to me like a relay or fuse then. BTW This is more of a Troubleshooting section
Old Sep 28, 2011 | 07:52 AM
lil' jeff's Avatar
mine did that and it was the iac valve (idle air control) maybe that will do it if not maybe the fuel pump
Old Sep 29, 2011 | 04:08 PM
D3rr's Avatar
Where was that valve located?
Old Sep 29, 2011 | 04:14 PM
lil' jeff's Avatar
its under the air intake tube on the throttlebody lil black round thing with 2 or 3 screws holding it in.
Old Sep 29, 2011 | 04:27 PM
lil' jeff's Avatar
its part # is MR578268 if you can find just that black piece,the only piece you really need then get it if not then you have to buy that whole piece which is crazy expensive!!!!!!
Old Oct 1, 2011 | 12:32 PM
D3rr's Avatar
mechanic said he checked that an it was good. thanks tho. He said he checked to see if any amps were goin to the crank sensor. an there is, then he checked the coils, an no volts are goin to the coils. any ideas?
thanks for the help so far
Old Oct 1, 2011 | 01:39 PM
mink's Avatar
Check your timing belt! Mine did the same thing i tested fuses,spark, fuel all that jazz and it ended up being that my timing belt went out on me
Old Oct 1, 2011 | 01:57 PM
03lances's Avatar
Could be a fried ecu. Have you tried swapping relays around to see if it is a bad relay?
Old Oct 2, 2011 | 07:17 AM
D3rr's Avatar
i tried a different front ecu already, I did try swapping around some but Im gunna try more. Il let yas know. thanks for the help!
Old Oct 2, 2011 | 07:50 AM
D3rr's Avatar
I have one and a half parts cars, so I may try switching the whole fuse box.
Old Oct 2, 2011 | 09:24 AM
03lances's Avatar
Oops how the hell I miss that at the top lol.
kjsperformace
Aug 1, 2017 07:01 PM
wray0812
Lancer Engine Tech
Oct 5, 2013 07:27 PM
luischav3z
Lancer Aftermarket Forced Induction Tech
33
Mar 29, 2009 10:24 PM
KingGreg86
Nov 9, 2004 02:40 PM
saucemaster
37
Aug 4, 2002 02:59 AM
