throttle body swap?
Old Feb 21, 2004 | 08:12 PM
PRLancer's Avatar
4g94??
i heard that the throttle body from the eclipse is completely compatible with the 4g94 in the lancer, is this true? is the eclipes throttle body better than ours? also i heard that the 88-89 rx7 high impendence injectors are compatible for the lancer, is this true? anybody know of a light weight flywheel for my engine? any help is appreciated. thanks
Old Feb 21, 2004 | 08:21 PM
brentg07's Avatar
i dont know about the throttle body, but i think Kobie ( cant remember exact name but hes a mod, hes got the crazy headers) knows about the injectors there is a post but i thought he said they were compatible dont hold me to that though find out from him. havent found a flywheel
Old Feb 21, 2004 | 08:25 PM
PRLancer's Avatar
thanks brentg07....do you know of any other parts that are compatible?
Old Feb 22, 2004 | 09:13 AM
Udontknwme's Avatar
Fidanza makes a light weight flywheel for the 4g94.
Old Feb 22, 2004 | 10:08 AM
bahamut's Avatar
A friend of mine hasn't made the injectors work yet. It's not sealing properly on the fuel rail. We have gotten longer bolts . . . Don't believed that he has hacked his harness.
Also, you don't need bigger injectors if you don't plan upgrading to a bigger MAF and tune it w/ an AFC. W/O tuning, you'll get erratic idle and fuel trim delivery. Ya, at 460cc for NA, you'll never able to tune it down with an AFC.
As for TB, there is more to that . . . you'll fight idle surges all day long. Maybe, 1 out of a bunch of miragers had tried this has fixed the idle surge. There are so many variables that we haven't isolated the problem. One of them is the sensor.
Old Feb 22, 2004 | 08:47 PM
HobieKopek's Avatar
Jesus, I'm not a rapist basketball Player.
RX-7 Injectors are rather large. Check the WRX before you check the RX-7. With these size injectors you'd certainly also need a higher flowing fuel pump.
Old Feb 22, 2004 | 10:24 PM
tenkawa_akito's Avatar
hi kobie
Old Feb 22, 2004 | 10:40 PM
brentg07's Avatar
sry HOBIE all i knew is that ur the man to find w/ questions
Old Feb 23, 2004 | 06:23 AM
HobieKopek's Avatar
I dunno about answering them all, but I help with what I can.
As for the TB...I would be slightly suprised if it fit, but if anyone happens to have a 1g TB lying around it's a really easy swap. Just unbolt and replace the coolant lines.
Old Feb 23, 2004 | 10:11 PM
KillahB's Avatar
Speaking on behalf of the 4G93 guys..... the 1G Eclipse works. My idle has finally stabilized 99 % of the time, guess the ECU took its time getting to know the TB.
RX-7 injectors, I am still playing with. Have not had time to put em in again, after the first attempt. I do have new o-rings and longer bolts for the fuel rail so when I get this done, I will let you all know.
Old Feb 23, 2004 | 10:26 PM
rhyzin's Avatar
lol... i have a 1g tb lying around.. but the throttle screw (not idle screw) is broken off... booooooo...
Willott03lancer
Lancer Engine Tech
Jun 9, 2015 12:22 PM
TJung
Apr 29, 2011 11:25 AM
sonic_evox
Oct 20, 2009 10:06 PM
Whooopasss
Oct 6, 2003 02:52 PM
lancer02Josh
Mar 18, 2003 04:46 PM
