Eclipse and Evo Engine Parts compatibility
Old Oct 3, 2003 | 01:31 PM
Whooopasss's Avatar
Registered User
Ok, I'm a newbie with mitsu engine parts. Since both eclipse and the Evo has the same 4g63t engine, what parts are interchangeable? HKS 262 cams for the eclipse the same part number for the EVO? Cam gears? Timing belt? Throttle body? ETC.
Old Oct 3, 2003 | 02:04 PM
HIGH REV's Avatar
Not all Eclipses had the fortune of having the bullet proof 4G63 turbo engine. Although the engine code is the same, the Evo 4G63 is different in many ways compared to the 4G63s found in the Eclipse GSTs, GSXs, and Galant VR4s.
Old Oct 3, 2003 | 03:05 PM
Whooopasss's Avatar
Registered User
ok.. how about the GST, GSX HKS cams, will they work in an EVO?
Old Oct 3, 2003 | 04:01 PM
1QWKEVO's Avatar
NO, only parts which are interchangeable are manifold, possibly intake turbo... however I don't know why you'd want those parts on it...
Old Oct 3, 2003 | 04:04 PM
Whooopasss's Avatar
Registered User
Ok. that is exactly what I wanted to know... cheers..
Old Oct 4, 2003 | 06:55 AM
Turbo-Weapon's Avatar
In Timeout
From: My name is Ananda Robinson.Stupid people should be killed. i live in Maryland
All Galant VR4's use a 6 bolt large rod motors. So do all 90-92.5 DSM's. You have different cams and slightly more compression 7.8:1 vs 8.8:1.
The 93+ model year DSM's have the smaller rod 7 bolt crank shaft motor that is crankwalk prone. If im not mistakes i remember something out if the proven camp. Suggesting that the stock EVO VIII rods are a tad thin. Again im not 100% sure in that Al or Dave would know better.
Old Oct 6, 2003 | 09:29 AM
Whooopasss's Avatar
Registered User
what I was trying to find out is, if someone is selling a hks 264 cams for an eclopse GST brand new for cheap, can I buy this and use it on my evo.
Old Oct 6, 2003 | 10:30 AM
rarson's Avatar
The engine rotates backwards and the cam gears are on the wrong side. Maybe they'll cancel each other out!
Old Oct 6, 2003 | 02:46 PM
Z1 Performance's Avatar
cams are not the same, exhaust manfolds are not compatible.
rods "should" be - have not had a chance to look myself.
pistons are different
Old Oct 6, 2003 | 02:52 PM
Whooopasss's Avatar
Registered User
excellent... thanks for the info.
user 0830829
Sep 18, 2008 04:18 AM
fromWRXtoEVO
40
Oct 26, 2007 11:42 AM
moviemadness
10
Apr 30, 2004 05:24 PM
intimidator2000
20
May 19, 2003 03:48 PM
Alfriedesq
Mar 31, 2003 11:25 AM
