Evo VIII And 2g Eclipse Engine
Old May 17, 2003 | 08:48 AM
intimidator2000's Avatar
One of my friends was telling that the engine that was in the 2g Eclipise is now in the Evo VIII is that true, he said that the engine code is the same.
Old May 17, 2003 | 08:49 AM
fury656's Avatar
Same engine code but a different variation and If i remember correctly oriented differently too.
Old May 17, 2003 | 08:50 AM
leonard_shelby's Avatar
4g63
Same block
engine is mounted opposite of the DSM cars tho
Old May 17, 2003 | 08:55 AM
Besides the mounting of the engine is there a diference between 2g Eclipse engine and Evo VIII engine.
Old May 17, 2003 | 10:14 AM
hollow cam / valves, diff turbo ( twin scroll)
Lots of others ..
But your friend can easily get 300+ HP from his 2G
I think you can really get any HP you want from any engine, its just a matter of how much cash you are willing to throw at it.
Look at the other differences brakes, stearing, gearing, overall handling.
Both great cars tho, I owned a 99 GSX prior to the EVO
Old May 17, 2003 | 03:56 PM
How about the crankshaft on the Evo VIII did Mitsubishi change that and the oil squirter.
Old May 17, 2003 | 05:56 PM
No ****ing idea.
I would assume that the oil (squirter ? ) pump would be beefed up so if your cornering really hard its still able to pickup oil.
maybe call a mitsu dealer for the part numbers ?
Old May 17, 2003 | 09:08 PM
How about the crankwalk issue if the engine are the same it looks like the the Evo VIII engine will have a problem with crankwalk.
Old May 17, 2003 | 09:47 PM
Speedlimit's Avatar
Admin Emeritus
Please re-read the above post. They have the same block and that is about it relative to similiarities. Different crank, rods, pistons, valves, cams, bearings, turbo,intercooler, intake, fuel rail........ etc. Crankwalk has NOT been issue with the EVO period.
Speedlimit...
Old May 17, 2003 | 10:43 PM
ACM's Avatar
ACM
Speedlimit...
What I have read on the DSM Digest does not support the above opinion. Crankwalk is equally evident on EVOs as compared to DSMs.
Charles Moss
Old May 17, 2003 | 11:21 PM
Speedlimit's Avatar
Admin Emeritus
Charles Moss
Hi,
This topic has been discussed here several times and the conclusion of EVO owners overseas was that crankwalk on EVO's was not an issue to be concerned about. Can it occur?.. sure; on my EVO or lawn mower or 1G Talon or Ford Explorer. Equally evident as on 2G DSM's? No.
Speedlimit........
Old May 18, 2003 | 03:02 AM
ACM do you have a website link on the DSM Digest that talked about the Evo VIII crankwalk.
Speedlimit why did the overseas site come to the conclusion that Evo crankwalk was not an issue to be concerned about.
Old May 18, 2003 | 09:27 AM
Speedlimit's Avatar
Admin Emeritus
Uhmmmmm...... because it has not been an actual problem with ealier versions of EVO's? The search function is your friend. Type in "crankwalk" and you'll get 2 pages of threads discussing the issue (or non issue). What is your concern?
Speedlimit.....
Old May 18, 2003 | 07:49 PM
Well I read before from my friend the search function and the previous Evo's did have a problem with crankwalk.
Old May 18, 2003 | 08:24 PM
Speedlimit's Avatar
Admin Emeritus
Good... you've drawn your own conclusions. Here is my point. I'm not concerned one single bit about my EVO crankwalking and I've not heard any other owner voice a concern so therefore it is NOT an issue for me and apparently others.
What is your point?
Speedlimit...
