spark plugs
Old Mar 5, 2004 | 09:25 PM
brentg07's Avatar
spark plugs
its about that time for the spark plugs to be replaced so i figured i would put some better ones in, just wanted some suggestions for which ones to use
Old Mar 5, 2004 | 09:26 PM
bobaab's Avatar
im using the Denso Iridium plugs, i think they are model # IK16..i might be wrong tho. They seem to be working great. they're kind of expensive tho.
Old Mar 5, 2004 | 11:24 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I have the NGK Iridiums (www.optauto.com should list the correct model). They have been fine for 2,000 miles so far.
Old Mar 7, 2004 | 09:22 PM
skyman's Avatar
I also use NGK Iridium, that's great.
Old Mar 7, 2004 | 09:25 PM
erockOZ's Avatar
From: Northwest Chicago Subs - Serving in Korea till 09
I've had my NGK's for just over 7000 miles and love them. I've heard good things about denso but they are expencive.
Old Mar 7, 2004 | 10:06 PM
TURBOit's Avatar
NGK all the way, cheap and do the job
Old Mar 7, 2004 | 10:13 PM
bahamut's Avatar
Iridium . . . I'm not big on them, unless forced induction + NOS + very aggressive timing.
Old Mar 16, 2004 | 05:25 PM
itscypha's Avatar
What about Bosh Plat 4's?
Old Mar 16, 2004 | 05:33 PM
blaze_125's Avatar
Exacly what I was about to ask... What about Bosh plugs
Old Mar 16, 2004 | 06:39 PM
XTXANDY's Avatar
The mitsu dealer recommended ngks or densos (they come with cheapy ngk plugs stock) he did not recommend bosch but i have teh platinums (not +4) and they have been fine for me.
Old Mar 16, 2004 | 06:41 PM
RacinMylancer's Avatar
i just got some denso's... i've yet to put them in... sorry about the off topic comment.. but... do i have to adjust the gap? and if so, what's the correct gap for the lancer?
Old Mar 16, 2004 | 07:40 PM
Moderator
Bomb Squad Unit #02
If you got the model listed for the Lancer specifically, they are already gapped. If not, you need to gap them.
Old Mar 16, 2004 | 09:40 PM
KillahB's Avatar
This is my experience with my car, even though it is not a "Lancer" per se.
Bosch Plats after a couple hundred miles, started fouling up and misfiring. Yep, they were gapped properly. NGK has been my plug of choice and I have had no problems whatsoever with them.
Go NGK, is my advice to you all.
Old Mar 17, 2004 | 02:20 PM
NEPA03ES's Avatar
I used to think platinums were the way to go, but the reason they foul out is because they are completely surrounded by ceramic. Platinum is a great conductor, but burns to quickly in this environment. It will eventually receid into its insulator. Poor spark. Iridium is great high density conductor. Ask a lot of people at the track(land or water) and they run standard NGK's. Good plugs, cheaper plug changes in an environment where they see heavy duty use.
Old Mar 17, 2004 | 07:49 PM
XTXANDY's Avatar
Yeah i'm going to go with the NGK Iridiums soon.. i just needed some spark plugs at that point lol
