2003 lancer oz 4g94...blowing ignition coil.
Old Mar 21, 2015 | 10:03 PM
EastwooD1's Avatar
Fixing it for a friend.. it had a bad head gasket so it got replaced along with decking the head, new valves, ect.. So car has been sitting for months so being the nice guy that I am I take on the project. Get it all together and now the coil closest to the timing belt is getting very hot after running for like 10 minutes. I have changed plugs, wires and both coils but that one is still getting extremely hot so I have disconnected it just in case while it is sitting. Any ideas why it would be getting so hot?
Old Mar 22, 2015 | 09:59 PM
OZR_Lancer's Avatar
coilpack ? did you make sure they were/are in correct firing order ? prolly would of checked that I bet.. possibly a bad coilpack ? are thy quality plugs/wires ?
Old Mar 24, 2015 | 09:43 PM
EastwooD1's Avatar
Yeah.. firing order is right. Plugs and wires look good, replaced the coil with a new one and it did the same thing.
Old Mar 25, 2015 | 06:44 AM
02modlanceroz's Avatar
I seen the same thing happen to an evo, ended up being a bad ECU.
Old Oct 26, 2021 | 04:40 PM
KennyC79's Avatar
you check that the coil wire and the crank position sensor are switched. both coil wires should have smooth wire harness cover crank position wire has ridges in its wire loom but the plugs are exactly the same and the same color. this will fry a coil a sensor and an ECU if you are not careful!
Old Nov 5, 2022 | 04:40 PM
2003bololancer's Avatar
The coil pack connector is the same as crank sensor
Be careful friends I made the mistake that’s cause me to get a new one ecu for my car
SnowGT
Lancer Troubleshooting
Nov 19, 2023 05:49 PM
juan5310
Sep 6, 2014 07:47 PM
JDM_CEDIA
Lancer Engine Tech
Apr 28, 2013 10:47 AM
Benja
Dec 17, 2011 08:49 PM
Boost3dxEvO
32
Sep 23, 2008 04:22 AM
